Don't get your hopes up. Kingwa told me a while ago to return mine for refund because the drivers would not be fixed.
TE8802 is far from the 'latest & greatest'; It is a budget solution. Even with the TCXO upgrade it is a jitter fest because of the way the chip tries to synthesize 44.1kHz and 48kHz clock multiples from a 12.000MHz crystal. Anything based on XMOS will destroy the DI-V2 in performance due to technical superiority -- largely because it uses discrete clocks for 44.1 and 48kHz multiples (22.050 and 24.576 MHz, respectively iirc) resulting in far less jitter.
Kingwa should skip the TE8802 and the USB-32 chip altogether and adopt XMOS for his higher end gear and the DI. One major bonus of using XMOS: the drivers have been updated over 50 times in 3 years with no end in sight (I just updated again a week ago).
They are. Based on the file timestamps the Audio-gd "v2" drivers were packed on August 8 while the Burson ones were done on June 7 and the contents of the .exe's are the same except the Audio-gd has larger icons by about 100KB.
One must be careful not to oversimplify....
ALL ELSE BEING EQUAL, a solution that uses separate clocks will have less jitter.... however, the quality of those clocks matters a great deal.
A single-clock setup (with a very good clock) COULD perform better than one with two poor quality clocks - one shouldn't assume.
Likewise, the DI uses a sample rate converter, which removes jitter from the signal.
(How well it does this depends on the DSP and its clocks and programming...)
Therefore, having moderate jitter on the INPUT probably really doesn't matter
since it will be removed along the way anyway. The jitter on the output clock, and the transmitter matter a lot.
The jitter on certain of the DSP clocks is also probably critical (which ones will depend on the DSP and its programming).
If you have it set to up-sample everything to 96k, then only the output clock that clocks THAT rate matters
(it doesn't mater if the derived-clocks for the rates you aren't using are especially jitter free or not).
Presumably KingWa is pretty good at knowing what matters and what doesn't....
(if not, then we shouldn't be buying his stuff
You shouldn't second-guess him without all the facts....
