FauDrei
- Mar 6, 2007
Try different USB cable. I suppose you already tried different USB port.
Now Burson as well as Yulong are both adopting the TE8802, good luck to them.
Hey we're all wrong, we should just sell all our equipment. Reddit expert electronic engineers know best: LINK
Edit: Feel free to lock and load and send back up !
Hey fella's just hopping in here to ask a quick question.
Right now I have a NFB-5 and have it connected to my computer via USB. Its got the older TE7022 chip and I see there is a TE8022 upgrade availible, but it seems some of you guys are having problems with that chip.
Should I keep the TE7022 chip I have, go to the TE8022 upgrade or wait for whats next?
Well are you unhappy with your TE7022L chip , does it sound bad ? furthemore It don't need any kind of custom drivers wich is not so bad .
TE8802 is reported to have some driver problem but hard to say if it's massive or just a little minority .
On the other hand Audio GD switched to "USB32" wich seam a bit more mature for drivers , USB32 kits should be avaliable when they will think that USB32 drivers are definitively OK .
If you can't wait ask for TE8022 upgrade bord otherwise wait then for "USB32" upgrade board be ready to ship .
Someone compared Audio GD DI-DSP with Hiface Two?
Considering there are 233 pages of mostly complaints about this Audio gd interface this is a very sane request. I own the Hiface Two and it never fails to work exactly as it should. The software works properly and the Hiface Two does it's job every time without errors. I can't find a single thing wrong with it or anything about it that I would change (and it is cheap). The original Hiface had some problems but this new version is flawless.
