This seems strange. Do you hear this from any other USB host ?
Thanks for getting back to me.
Seems to be a problem with my phone, I do not have any problems when they're connected to my PC.
They're beginning to grow on me and sound quality is actually
really great... my only gripe, the whole frequencies seem to be slightly panned to the left, beside the higher up frequencies 8khz to 10khz, no matter which mode I'm in - although, in the gaming modes it's even more evident. Any tips for that
@Audeze, or will I have to return them for another unit? Also, any way to connect them to the lightning port of my iPad directly?
Just to sum up my very first impressions with them:
Positive:
- Comfortable! Good looking! Robust even though it’s pretty much all (high quality) plastic (which helps keep weight and cost down!)
Really good planar magnetic sound quality
- I'm a fan of the EQ modes*
- No audible distortion even when they're turned up to very high volume
- 3D Mode is impressive to say the least, especially because it makes the sound play in front of you, making it feel like you're listening to speakers rather than headphones. *slow clap* (I can imagine that this reduces listenting fatique as well)
- "Room Ambience" (Basically reverb) can be turned off through the application. Thanks for that! Now listening to Music with the 3D Mode activated sounds more natural IMO!
- Connectivity: Easily plugged into any PC (can't wait to use them at work), Bluetooth pairing is a breeze
Neutral:
- A bit bulky, weighty, but packed with so much technology that it's okay again
Gripes:
- Mentioned pan in sound to the left
- *Gaming EQ modes increase the left-pan
- 3D Mode is always activated by default, even if I turn it off - would be great to have the ability to just save the previously selected mode before the Mobius are turned off
Further feedback:
Maybe there could be an option to use 3D Mode without the head tracking? I think that may be rather useful for listening to Music especially. Would surely be great to just have this option as a little checkbox in the application or something.
EDIT: When trying to configure them through windows, the prompt window for it just closes without letting me make any adjustments. Did anyone else experience this before?
EDIT2: Is anyone willing to send me the firmware update? I've contacted support, but it'll probably take until Monday - Tuesday until I get a reply and I would
LOVE to try the "Warm" EQ mode.
@Audeze, maybe you could drop me a PM as well?
Also, please allow saving the last configuration for both 3D and EQ mode! Evertime I turn them on again I have to scroll back to the Music EQ mode. It doesn’t take long of course, but it is still rather annoying.
