koc
- Aug 5, 2009
I will try, Thank you man.
Try switching off charging on the Mobius (long press on the volume wheel).Hmm,
I have the 1st gen cck that I just purchased from apple store. and It did not seem to work with my iphone. I did not get the USB-C to USB-A cable though. But I have a similar cable that works when connecting from my computer (USB-A) to the mobius. Any ideas?
Yes, you created a ground loop by double connection, and Mobius is quite sensitive to PSU noise and hum on the USB input.Today i tried charging my mobius while it was connected to my ps4 controller and it started to buzz very loudly....is this normal?
Strange...never had this happen with other gaming headsets ive previously owned. Well atleast now i know lolYes, you created a ground loop by double connection, and Mobius is quite sensitive to PSU noise and hum on the USB input.
This is most likely a grounding issue.Today i tried charging my mobius while it was connected to my ps4 controller and it started to buzz very loudly....is this normal?
Stay updated on Audeze at their sponsor profile on Head-Fi.
I recieved an e-mail last week to confirm my shipping adrress for the stand, and got my tracking numbe on Friday.
Iirc i was #4 , If that helps any.
I just got a response from Audeze support saying that the 3PL has lost my package and that they will be shipping a new headset directly from California instead. For those of you that have been waiting a month or more for UK customs clearance I suggest you email the support as well.
Even though this turned into a mess I have been positively surprised by how helpful the customer support have been, kudos to Audeze for that!
Anyway, the new estimate is for it to arrive next week. Can't wait for it
I died a LOT tonight in-game due to the sounds apparently originating behind me, only to have the player appear in front of me. At first I thought it was a game audio bug you run into occasionally where sound is reversed, but this was random, and inconsistent. It was so bad someone asked me if I was letting a guest play on my PC.
I have been waiting with baited breath for a decade for someone to actually put out a high-end gaming headset
. I really thought either Ossic or Audeze were going to change gaming audio.
Sorry for venting! I am just tremendously frustrated and disappointed right now.
BTW: If anyone is using these on high-end hardware successfully, I would like to know. My PC is running an Asus Rampage VI Apex board, 7900X CPU, G-Skill TridentZ 3200 Ram, Seasonic Prime Ultra 1000 watt PSU, Multiple Samsung NVME 1TB SSD drives, and an EVGA GTX 1080ti GPU.
BTW: If anyone is using these on high-end hardware successfully, I would like to know. My PC is running an Asus Rampage VI Apex board, 7900X CPU, G-Skill TridentZ 3200 Ram, Seasonic Prime Ultra 1000 watt PSU, Multiple Samsung NVME 1TB SSD drives, and an EVGA GTX 1080ti GPU. All with the latest stable Drivers, BIOS, and Firmware.
I want to buy longer USB-C to USB-C cable, any recommendation?
I believe i need cable with at least 3 Amp but what about voltage?
Better to look for something along the lines of "Made in Compliance with USB Specifications" so you're getting proper impedance matching. But any well rated cable should be fine, just go with active if it's a much longer(10'+) distance. For charging I believe the mobius takes 1amp max.
Well what they're trying to do is update the hq app to be able to do the firmware updates. Vs having to us a dfu mode on a firmware flasher.No issues to speak of, but rather new features they were talking about adding, like the music preset memory after power cycling , or the ability to turn off head tracking without defeating the 3d processing. I know they are working on those features, but if they're not ready yet it's OK I can wait...
I see 10 USB ports on the "Asus Rampage VI Apex board", doesn't Mobius work on these?Well, I am now in the queue waiting for a response from Audeze for either tech support, an RMA, or a refund. I don't want to bag too hard on the company, but this has been an exercise in frustration and disappointment. I really wish the sound sucked, because then I could fairly hate on these things across the board, but the sound is sometimes amazing. As for everything else, the product is up to its nose in tech debt, with not much to show for it. Worse, given mine are not just fighting me in games, but have already failed, with less than 10 hours of use, I have to say that they do not appear in any way to have provided a good return on the investment. Most of the headsets I have used for relatively competitive gaming over the years have been easier to use, worked more reliably, and apparently more durable to boot. The last straw (before the left channel died, that is) was the fact that I could not ignore blatant inaccuracies in sound localization. I died a LOT tonight in-game due to the sounds apparently originating behind me, only to have the player appear in front of me. At first I thought it was a game audio bug you run into occasionally where sound is reversed, but this was random, and inconsistent. It was so bad someone asked me if I was letting a guest play on my PC. These are marketed as game-changing Gaming Headphones, but I get better gaming performance from Logitech and Turtle Beach, both of whom I basically despise. I would write this off as a interesting experience, and just use them for music and movies (which I do not spend much time partaking) but I can't get them to work at all on a relatively new gaming laptop, or my older, rock solid gaming PC. My new gaming PC now has no sound output device other than HDMI sound via my display. I sure as heck am not corrupting that PC with Logitech software and my crappy G933 headset... so I might have to grab the 1More Spearhead VRX cans until this gets sorted out. I have been waiting with baited breath for a decade for someone to actually put out a high-end gaming headset. I really thought either Ossic or Audeze were going to change gaming audio.
