headitaly
- Mar 8, 2016
Remember when using the aux input the headset is performing an additional analog to digital conversion before going through the builtin digital to analog conversion and additional dsp. The headphones are battery powered at all times so if volume is low on the aux input its due to a lower signal level and not amplification/power. Always shoot for using the usb connection or ldac/aac bluetooth as that should give you the best signal quality and full use of the builtin battery, which can get excessively loud.
Battery life is shorter due to the demands of the binaural rendering dsp, as well as bluetooth if using it, and equalization dsp. Recommend keeping a battery pack handy for charging if not using a pc. Battery replacement isn't user serviceable and would require rma.
ok, but is it possible, or the life of mobius = life of its battery? based on the cost is a headset that can be kept for years
