I believe you are referring to the measurments made on minDSP EARS, which tends to have an artifact/resonant peak near 4.5kHz and is not real. Which is why I had posted measurements we made on GRAS Kemar (https://cdn.head-fi.org/a/10262463.png) .I was referring to the charts on the first page of this thread that have a boost at around 4,5Khz, could you point me to the charts you posted?
We should probably clarify I'm talking about 2D mode here, I'm using LDAC Bluetooth in 96Khz mode from my android. 3D mode from my computer sounds fine without EQ (although I wouldn't mind a little more bass)
People have described these phones as treble forward, and compared to other phones I've used I'm inclined to agree.
I've been looking for a way to make them sound less harsh, I had concluded that it was somewhere in the lower treble/upper mids.
Which preset do you use? Default would be my recommendation without 3D on, followed by Music and Warm if you want it to have less treble energy.
Preferences are what they are and I will never advice change that. The reason for my response was your post made me think you were making the changes based on measurements.People have described these phones as treble forward, and compared to other phones I've used I'm inclined to agree.
With the 3Khz cut I described above, music sounds less nasally, cymbals sound more like they should, the soundstage is better separated, Music sounds much more in line with headpones/speakers I've been using for years.
When using HRTFs, especialy convolution based (which Mobius does not use), you will have to compensate /invert the headphone response to avoid a 'double HRTF', so I am not surprised by what you had to do. But Mobius already does that in 3D mode, though we do not overdo it (For all presets except default and flat),Here's the EQ when using OOYH for
