borrego
- Jun 19, 2008
I think the LCD-X and XC have 8 magnets across, 2 more than the LCD-2:
HE-6SE V2..my mistake on version.You might be thinking of he560 v4, not he6se
I do remember the LCD-2 having that alu. cup through Adorama or similar, not sure of LCD-X though...you may have an over-priced set of grills...For the record the "Franken-LCDX" I got has 8 magnets just no fazors.
Maybe. I do know it's not the LCD 2 tuning as I've owned 3 of them in the past. I've owned 1 previous LCDX and the tuning seems much more similar to that.I do remember the LCD-2 having that alu. cup through Adorama or similar, not sure of LCD-X though...you may have an over-priced set of grills...
hi i bought an lcd x creator edition and threw away the carton, how can i know if the model i have is a 2020 version that the dealer sold me
mine has the metal mesh under the grills
The metal mesh is indeed a 2020 revision.hi i bought an lcd x creator edition and threw away the carton, how can i know if the model i have is a 2020 version that the dealer sold me
no not at all, but it sounds different than my old lcd x which i bought in 2015, i do not have the box or anything related to it, i just have the headphone, and get this new headphone from the dealer and by mistake threw away box as its just creator edition , and everything included in it except the cableI guess check with Audeze themselves using your certificate of authenticity - there is a serial number there. If you supply them that, they should be able to tell you if it's 2020 version.
Any reason why you think it's not the 2020 version?
