Stereolab42
- May 11, 2014
Wanted to share a suspension strap idea I had that worked out surprisingly well (I do my best thinking in bed)
I went through a vintage AKG phase a few years back; the only remnant being a K240 Sextett MP in stellar shape that I couldn't bear to part with. It turns out with not much effort I was able to rig the headstrap it onto my LCD-X headband, improving the comfort by a large margin:
Others will disagree, but I really l really like how it looks as well, it adds a nice vintage aesthetic to the X. Sextett headbands aren't terribly easy to come by, but since AKG has been using the same design for decades a new K240 headband should work just as well: http://www.fullcompass.com/prod/015012-AKG-2058Z0902
Of course, this shares the same caveat of the Lohb strap in that those with larger heads will need to purchase the extended yokes. Otherwise, it's a very simple and inexpensive way to increase comfort if the stock band creates a pressure point at the very top of your head as it does with mine. It only requires removing the two screws from the top of the yoke rods, sliding the headband off and reassembling as shown (it was a bit tricky to get the tail ends of the K240 headband to fit onto the top of the rods).
I have some assorted scrap leather at home; at some point next week I'm going to use the K240 band as a template to make a leather version as well. We'll see how that goes!
This is genius. I just got my straps in from FullCompass and installed them on my LCD-3 and LCD-XC at home. They fit perfectly as showed in the pictures, almost as if they were specifically made for this purpose! They are very comfortable and a lot better than the Lohb straps (on those the loops would always pull out of adjustment). Including the $30 price of the extended yokes, you still save $120 over the Audeze carbon fibers (which they couldn't even manufacture correctly the first time).
