peter1480
Think again, you need to try the LCDi4Deep low bass from earphones or headphones? I think it will become possible only with big and well-made speakers.
Like Wilson Audio's big speakers.
I'm trying new AUDEZE Reveal+ Plug-in with JRiverMediaCenter25.Using my LCDi4. About Aural Map, only Ambience can be operated. For this is a trial version.
Is there anyone trying this plug-in with LCDi4?
I'd really like to try this version of Reveal, but I can't seem to find it anywhere. Where do you download this trial?
Go to Audeze.com and search reveal. Go to software section and it will be there. They also have the old reveal plugin so make sure you are not on that page. Add to cart as trial and checkout.
Thanks I tried the search but it only turned up the legacy plugin. If I go to the software section the new plugin is there as you said.
I'll get a chance to try it out later today.
I'm curious too to hear impressions if anyone has tried it yet.
What do you want for headphones? I don't want my LCDi4 bass slam. And I disrespect the low quality bass sound of only amount.
Wilson Audio's big speakers has very punchy powerful bass. The sound is worth the price. Subwoofers? Out of questions.
Only spec. Don't abuse the great speakers. I think LCDi4's bass reproduction ability is superb. But it is other story.
I don't want bass slam for earphones nor headphones.
Just stop it. Puppy is a "woofer" unit. When the watt+puppy system started, Wilson made subwoofer "WHOW". I listened to watt+puppy+whow system some times.As I said earlier, you can not get the 'visceral' bass from headphones, from any headphones. Audeze i4 can easily be equalized to be flat at 20Hz, you can't ask more from any audio transducer.
You say subwoofers are out of the question, I'm going to give you an example how Wilson Audio approaches low frequency response in their loudspeaker design. Many other hi end loudspeaker designs are similar - low frequency unit is physically separated from mid and high frequency modules. That low frequency module is a subwoofer.
Wilson Watts, often stated the bestselling hi end loudspeaker of all time. Design is over 25 years old, currently in its 8th reincarnation, Wilson W Puppy 8 ($28.000, 4 driver, floor standing full range loudspeaker). You can buy monitor and bass module (subwoofer) separately, if you only need a, say, mini monitor. Watt is a 2 way monitor, and it sits on top of a subwoofer - Puppy. Watt was initially designed by Dave Wilson as stand alone monitor. It cost around $5000 in late 80s, when released, mind-blowing amount for small 2 way mini monitor. People wanted more bass, Dave Wilson designed a subwoofer for Puppies. Since then the Watt and Puppy's are sold together, together they form a full range loudspeaker.
But since you mentioned Wilson Audio, you must know that all Wilson's TOTL loudspeaker systems have bass enclosure separated from other drivers, Wilson WAMM, Wilson Grand Slam. This is to prevent inevitable low frequency resonances affecting mid range driver and tweeter enclosures.
All Dynaudio top models, the Confidence range floor standing speakers have bass drivers in completely separate enclosure, i.e, subwoofers are separated from mid and high frequency enclosures.
Wilson Watt Puppy 5, note the monitor (Watt) sits on top of a separate subwoofer (Puppy):
Thank you for the report. I still have only vague idea of Reveal+. I have to do more. Thanks.I tried it out last night. At first use - I'm not a real big fan of what the "Aural Map" is doing with the top end of my music. Gives me that nighclub bathroom kind of vibe. I've tried all the angles and can't find one that is a good compromise. I feel like it is taking too much away from the original track.
