triggsviola
we tried multiple amps/sources, including balanced. They all hummed!The RF Interference is probably come from the amp. Or source
The best place to start is with a battery powered source to see if you hear the hum, say a laptop on battery to a battery powered DAC if you have access to one, this way you are not connected to mains in any way. Does the hum increase/decrease when you touch one of the components?we tried multiple amps/sources, including balanced. They all hummed!
No hum when plugged into my iPhone dongle.The best place to start is with a battery powered source to see if you hear the hum, say a laptop on battery to a battery powered DAC if you have access to one, this way you are not connected to mains in any way. Does the hum increase/decrease when you touch one of the components?
Since you have tried it with more than one cable and also in more than one location, it is best to contact support.
I had a similar experience the other day. My source is a PC. I use a wireless keyboard, but if I plug the keyboard into an outlet to charge and touch a metal portion of the keyboard, I can pick up hum in my LCD-5s.I just received my Audeze LCD-5 and I'm having some trouble. It is plugged directly into my TT2 and it is making a 60HZ (or maybe 120HZ) tone. It's faint until I touch my keyboard that's plugged into my computer, at which point it gets very loud. This happens whether the TT2 is plugged in to the computer or not. It happens when the computer is off. It happens when the TT2 is in standby. It happens when plugged into another amp. This does not happen at all with any of my other headphones (Audeze LCD-XC , Focal Utopia, or Sen 6xx). What do you think could be causing this ONLY in my LCD-5? It's very frustrating.
I get a hum with my LCD-5 as well when connected to powered equipment. When connected to battery-powered equipment, it’s not there.I had a similar experience the other day. My source is a PC. I use a wireless keyboard, but if I plug the keyboard into an outlet to charge and touch a metal portion of the keyboard, I can pick up hum in my LCD-5s.
I happened to have an iFi DC Blocker on hand. I plugged it in between my power conditioner and the power cable to the wall, and the hum I heard through the LCD-5 stopped.
https://ifi-audio.com/products/dc-blocker/
I’m not advocating for this as a general solution, but it worked in my system.
It was more of a hum than a whine, and it was apparent during the quiet parts of music. It’s possible you’re hearing something similar. I assume it was noise from transformers like you might pick up with speakers connected to an amplifier, as the DC Blocker is meant to address that, but I can’t say for sure. Apologies, but I’m ignorant on electrical issues.I can hear a faint whine past 1-2 o'clock on the WA7. Is this the same?
Yes, corrected. It's more like a faint hum and can start hearing it around 1 but stays at that level all the way to max with nothing playing. Will try this blocker thingy. Thanks!It was more of a hum than a whine, and it was apparent during the quiet parts of music. It’s possible you’re hearing something similar. I assume it was noise from transformers like you might pick up with speakers connected to an amplifier, as the DC Blocker is meant to address that, but I can’t say for sure. Apologies, but I’m ignorant on electrical issues.
Just make sure you buy it from somewhere you can return it if it doesn’t work, like Amazon.Yes, corrected. It's more like a faint hum and can start hearing it around 1 but stays at that level all the way to max with nothing playing. Will try this blocker thingy. Thanks!
It's not a torx-head screw. I don't know why you posted this, as it has now confused people.Torx, not star.
Use the correct tools to do the job, and don't use a metric Allen key on a Torx head screw.
So, I adjusted the stems a notch lower so the cups sit lower and the ears are less pressured. I used them for 6 hours last night with less occasional adjustment or opening of the cups having to be done, so YMMV.I am afraid I'm going to have that problem. I love listening to headphones but my ears are, shall we say, "elephantine"...something is always rubbing against the pad or grill. And having large pinna doesn't help so I need huge openings in earpads to fit comfortably (even LCD 2-4 earpads or Empy earpads needed constant adjustment). So I either need to:
1. Trim all the external ear bits - although that just might affect the sound...or
2. Glue all the sticky-outy ear-bit parts to the sides of my head and hope the pads work on-ear...
Further helpful suggestions would be appreciated...
Cheers!
-HK sends
Mine came like that too and I see that @WaveTheory point it out in his video too. I use this tool to adjust the screw inside to make it tigh, it works fine now.
I dont know the number or name of the tool but is one of those for open electronics, I had lucky to have one on hands, it would be nice to see @Audeze include this tool with their headphones (also works with my LCD X) its more useful than the white gloves imo.
@Terco mentioned "Audeze includes this tool with their headphones" (in the photo above) which is a Torx driver.A 2mm hex key or T8 star driver (what's in your picture) will work.
