Audeze LCD-2C Classic - Impressions Thread
Oct 16, 2018 at 11:39 AM Post #3,781 of 7,334
cascade is close to atticus, but of course atticus is better, as cascade even more genre specific than atticus is
cascade has its own magic with certain specific genres which surprised me, an example is dead can dance - song of the stars, and as such genres. Sometimes you feel with it a wow factor and other times, you just can not use it with other genres, it is not that great with metal music or progressive rock. I loved the cascade for its sound in certain genres only and portable form factor. But for me to have a headphone that is genre specific does not sit with me well
Lcdx, HE x v2 and HE1000 V2 can be enjoyed to max with all genres
Well, damn....
After looking at your profile and seeing a lot of the same headphones as I have and a lot of the same impressions of them, then what you say about the Cascade, and I even listen to prog... I have to assume you're correct about the Atticus too. Hopefully, I will still like the headphone based on one crucial difference between the two of us: I don't mind genre-specific headphones. I think I'll look into the HEK and HEX in the meantime.
Man, I was really hoping you were full of crap... :laughing:
Oct 16, 2018 at 11:43 AM Post #3,782 of 7,334
Well, damn....
i had to learn it the hard way by buying and trying them myself, but do not fret as I always set the bar very very high for anything that takes my stamp of approval :).
if you never listened to an lcdx or HE HE1000 V2 then of course you might like atticus, but it was as well the impression of a friend of mine who as well owns over 10 totl flagships, we could not get to the point to give the atticus the stamp of approval :), we just said yeah its ok good for some genres
now if you want a real end game headphone just buy a Hifiman HE1000 V2 and be done with everything, that headphone simply is the best I ever heard in everything period, and it is light so no issue with weight, and it is way way way better than lcd X
Oct 16, 2018 at 6:15 PM Post #3,783 of 7,334
Hm, which LCD would you guys say is the best for jazz, orchestral and classical?
By the way, updating to the Dekoni Velour pads takes away ANY shouty-ness that was present with the original pads.
Furthermore, the comfort is improved in my opinion.
Oct 16, 2018 at 7:26 PM Post #3,784 of 7,334
I like the X or the 2F the best for those genres. Neither does brass instruments perfectly, but separation, imaging, and sonic weight (which I feel people overlook when pairing a headphone to classical music) are excellent. The X more so, of course.
The non-LCD EL-8 does an excellent job with that music and does so perhaps in a more expected way, i.e, more delicate, ethereal, crisp, and clean. Brass sounds much more realistic too.
Oct 17, 2018 at 12:35 AM Post #3,785 of 7,334
Hi guys, my current setup is McBook, Topping D10, Schiit Loki Mini, Little Dot 1+, LCD-2C.
I know the D10 is a cheap one but I'm very happy with this DAC for now, same with Loki. My doubts are on the amp: no problem about power, I never get passed 9-10 o'clock and there's plenty of power to drive the LCD 2C. But what about sound quality? I've never tested the headphones with a more expensive amp so I'm not sure i'm doing LCD 2C justice. Would my Audeze benefit from a better amp in terms of SQ? I was looking at the Asgard 2, would this be a good match? Any other recommendation in the same price category? Thanks!
Oct 17, 2018 at 1:00 AM Post #3,786 of 7,334
I think it all depends on your personal preference as to what kind of sound you are looking for, as well as what you have personally heard before as a baseline. I’’ve listened to my lcd-2c on a massdrop o2 desktop edition amp, Jds labs El amp, and schiit magni 3. Using a topping d50 which should be close to your dac I found the o2 and El amp very similar. Maybe the only real difference i could tell if any between the two was a more black background between the instruments with the El amp vs the o2. Both powered the lcd enough where i never even got near 12:00 on the knob. Both were deatailed and smooth with plenty of heft down low from the Audeze.
I hated he magni 3. Hated it so much. It made the treble too peaky and the mids were even more shouty than normal on the 2c. I was like you going to get a asgard 2 in the hopes to get a warm amp that was darker than my el amp and o2 that are supposed neutral amps, but I ended up getting the loki instead and after tweaking the highs and mids a bit on the magni 3 I now prefer it over every oher amp with the lcd2c. I might still get an azgard 2 to try, but I’m waiting on a thx aaa linear amp that is supposed to be the king of mid-fi neutral wire with gain amps. I don’t want to end up with more amps than I have a place for. If you do get the asgard 2, let me know what you think.
Oct 17, 2018 at 3:34 AM Post #3,787 of 7,334
In the same price category you can just find slightly different taste of sound, not much difference in overall sound quality. IMO noticeable overall sound quality jump happens in about '£500 steps'. You need to jump to the £1000 category to experience a significant improvement to those £500 DAC/amps in resolution, balance and details. At least this is my experience.
And another thing to keep in mind is that you need to improve your DAC and amp pretty much the same time. A cheapo DAC will hold back a good amp to shine through and vice versa.
Oct 17, 2018 at 5:36 AM Post #3,788 of 7,334
Thanks betula, I suspected this would be the case.
So, would you say the £250 Asgard 2 or similar in the same price category is not a significant step in SQ compared to the Little Dot 1+, and I'd better save up? In this case, any recommendation for a good amp in the £500 category? Thanks
Oct 17, 2018 at 10:24 AM Post #3,789 of 7,334
I don't know your budget, sound preference, ears, but in your case I would rather save up.
On the other hand you might like the Asgard 2 and think it is a worthwhile change. This hobby is very personal. Trying different gear is part of the fun.
All I am saying if you want a significant leap in overall sq and not just different sound signatures, you need to jump a category (if you can afford).
I am pretty sure others will recommend a lot of options around £500, many seem to like the iFi Micro iDSD BL at that price. Lyr3 worth a thought too with multibit.
Oct 17, 2018 at 11:15 AM Post #3,790 of 7,334
Sold my 2Cs, dont need 2 different planar at the same time, in the end I prefer Sundaras tighter and brighter sound a lot more.
Oct 17, 2018 at 11:23 AM Post #3,791 of 7,334
Do some research on the Asgard 2. It is generally thought to be rather warm-sounding and may not match well with the already warm 2C. I don't own either, so I won't advise one way or the other, but look into it.
Oct 17, 2018 at 11:24 AM Post #3,792 of 7,334
Happy for you. Most of us feel the opposite way in this thread.
Oct 18, 2018 at 6:30 AM Post #3,794 of 7,334
I eventually went for the Arcam rHead. Found a good deal for a new one here in UK and should arrive tomorrow. By reading the very few but all positive reviews of the Arcam this should be a good synergy with the LCD2C. Well, I'll have the whole weekend to find out
Oct 18, 2018 at 6:49 AM Post #3,795 of 7,334
Looks like a decent little budget amp. Good luck with it!
