Audeze LCD-2C Classic - Impressions Thread
Discussion in 'Headphones (full-size)' started by XERO1, Oct 7, 2017.
124 125 126 127 128 129 130 131 132 133
135 136 137 138 139 140 141 142 143 144
  1. Zoom25
    For anyone that doesn't like the comfort (clamping force) or sound quality upon getting it, give it some time. The earpads get broken in and you will notice less suction effect. The headband will also clamp less over time. You can also stretch it out if needed. I remember it being very hard in the first few days.
    I reconfirmed it as I had gotten a replacement headband and after being very comfortable for a month, it went to brutal again. Time to break-in this headband. I have definitive proof side by side, so it's not a figment of imagination. As the clamp changes, the sound also changes a bit. A well broken-in LCD-2C is a pleasure.
  2. Voxata
    Keep listening... Give it plenty of head time before swapping. That's all I can say.
    fivedollah likes this.
  3. anoxy
    Agreed, mine are quite loose now and will wiggle around on my head if I shake it, so clamping force is never an issue. I have a strong neck, so the weight is also never a problem, and idk how it ever would be unless you're slouching. If you're sitting upright the force should all be down into your spine anyway.
  4. Voxata
    Here is MY secret folks. Pay attention to the MY.. YMMV :) Chain makes or breaks my experience with these cans. Colin, I didn't fully enjoy the LCD2C off of the iDSD BL. It didn't sound bad but.. it doesn't come close to the stack. If you get a chance to audition Bimby/Jot on them.. holy crap (Make sure you try Gen5, big difference vs my PC onboard SPDIF optical).
    Best pairings I've found in audio to me:
    LCD2C+Jotunheim+Bifrost Multibit Gen5 USB + These settings:
    The iDSD however does AMAZING with bass sticker removed K702 using these settings:
    The iDSD/702 bass sticker mod is really, really good. Bested only by the LCD2C. The 560s are going back - I don't have the chain synergy either way to make them shine. Happy hunting all - I know few are lucky to have two incredible setups :) Oh, yeah yeah - I like LIGHT eq. The K702 sounds bloated no matter the fiddling on the schiit stack, and the LCD2C doesn't sound as full and mindblowingly good on the iDSD. Synergy folks, synergy. Enjoy your taste testing all!
    PS: The iDSD BL sounds much better than the stack as a preamp to my JBL LSR30X's.. synergy folks!
    trellus and tuby sound like this.
  5. anoxy
    Sorry, not in the know with the pet names.....Jot = Jotunheim? and Bimby = Bifrost Multibit?
  6. Voxata
    Correct(ed)
  7. ShamuellJackson
    Is there anyway to get rid of the ear pad smell? Its not as strong as it was when I first got them and for long listening sessions it's still there and rubs off on my ears to the point it bothers my wife. If not are there any pads to change with these that wont change the sound much?
  8. Rinsushi
    For the people who have the Roon EQ for the classics how are they? I've been using the old LCD2 on EQ APO. How do the two compare? Thanks :D
  9. Zoom25
    The normal LCD-2 EQ on Roon is not suited for LCD-2C. The 2C is definitely better suited for the 2C.
    With the normal LCD-2 EQ on the 2C, you'll hear differences in bass and midrange response. However, there is something irritating about the sound after awhile. I preferred no EQ over the LCD-2 EQ preset. The 2C preset is more subtle and better suited for the 2C.
    I still haven't decided whether I prefer them with or without this new LCD-2C EQ. It's going to take some time.
  10. wazzupi
    So quick update ill be receiving my sonica tomorrow and my eikon arrived today 15 days later... My lcd2c was sent in for repair and arrived at audeze on monday so hopefully ill have them back next week.
  11. Taverius
    3 days in, and sure enough, the strap has stretched enough that I have a hot spot where it touches the arch.
    Anyone know if its possible to mod it to be shorter?
  12. Voxata
    Repair? :frowning2:((
  13. wazzupi
    My right driver gave out could of been that pressure thing people keep talking about
  14. Voxata
    Yeah definitely put it on and take it off real gentle
  15. wazzupi
    I do but it was during a quick adjustment that might of done it.
