rhythmdevils
Member of the Trade: rhythmdevils audio
- Feb 11, 2005
So Lunatique, have you bought the LCD-2 yet?
just curious
Well Sir, I wasn't hoping for so very much, and I wasn't disappointed. They make noise, but are far from optimal as they run out of steam rather quickly. If you listen at medium-levels consistently you can make it by. That's been the finding with most (not all) op-amp based...keep it down, and don't expect the World (or optimum performance), your O.K.
Moar Powah = Moar Bettah...
Did you use your Moth with 800s?
I have heard a solid state i liked with the 800s, it was a balanced set up B22. I was impressed with that so my mind is open, and it is open to the LCD-2 also, whenever I get the opportunity to hear them. I realize that you are not a fan of the 800s though and I am not here to change your mind. I listen to several different phones, the HD800s just end up being on my head more than the others, i must like the sound more.
Edit-oh it was you I asked about the Lisa, sorry couldn't remember, and no I missed the response....so that kinda knocks me out of these phones for a bit in that they would require a whole new amp setup.
I'll pick on the Schiit amp since it's the FOTM and is being advertised in very deceiving ways.
I think the distinguishing of peak vs. continuous power ratings has come into question from some. It would be a non-issue for me as it's cheap and has reasonable power. What is the official gain of the device published/established at?
So tell us more about these deceptions to which you refer.
Thx,
k
I already covered it in this thread. It's being advertised as a high-end audiophile amp with very high peak power output, when in reality the RMS power will be very low once it is up to temperature. In my eyes, this is no different that the car stereo amps at Wal-Mart claiming 200W + 200W when in reality, it might deliver 5W per channel at 1.7% THD. But they advertise it as a 20V peak Class A at 315mA. Let the amp get good and hot, ground the input signal and measure the bias. That's the real bias, when the FETs are hot and the amp is stable. It's not illegal to make the claim they make, but it's deceptive.
If I'm shown a shot of an amp that's up to temp and running nice and hot with a iR temp reading visible along with a DVM showing the correct mV reading for the bias based on the measured rail voltage in the same pic with a Kill-A-Watt meter showing the hot amp still drawing 35W from the wall, I'll admit I was wrong to believe they are being deceptive and I'll congratulate them on having the balls to sell an amp to the public that is dissipating 35W of power through its aluminum chassis plate without current soaking their PS iron to cause voltage drops or heat soaking the chassis to the point that the MOSFETs throttle back output power for $250. Until I see that pic, I choose to remain a skeptic and view their marketing as deceptive along the same manner as the "Panasony" 400W car amp at Wal-Mart. If I see the pic, I'll admit I was wrong and eat my humble pie with some Cool Whip.
I think any amp manufacturer that makes peak power claims that aren't at full operating temperature and full spectrum are dishonest or deceptive. That might reel in many sponsors here on H-F. So be it. It's my opinion. If they want to publish peak power or peak swing fine, but publish the RMS specs over the full bandwidth too. The most reputable companies that have engineered a great product tend to to do that already though.
How am I being dishonest or deceptive when I write that I'm skeptical of their claims or that I feel their marketing techniques promoting the peak power is deceptive when RMS power and frequency range it was measured over isn't published. You may not feel it's deceptive marketing where as I do, but that sure as hell doesn't make me dishonest.
...and another test.Perceiving apparatus on human beeings is very complex but you can remove a little bit imagination when picture is added in a performance.Yes you can run the LCD out of i pod as well as Grado PS.If sombody has on hand both phones can make the following test.
download the following performance on high resolution
http://www.youtube.com/watch?v=VFONNkZ4v1A
check out the lady how she treats the guitar.So how much information you get from this live performance and how much information is on that guitar.No question about it the PS gives subtle resonances, you hear clearly the body of the guitar ,every finger tipp and every string on that guitar is audible-this is almost real life.When i put the LCD on my head and tune my attention to this performance i miss the ultimate live airiness i miss the ultimate resonance from the guitar although everything is "there" with LCD but not in that real life way as PS does it.
You didn't write that you were simply skeptical, you wrote that the manufacturer was being "deceptive." There's quite a difference.
You are entitled to your skepticism, but you are not entitled to publish your skepticism as fact until you've proven it.
C'mmon, man, frankly you're wrong! Instead of evil surmising, prove what you're saying. My amp does not act anything like what you describe. If the max power output declines when the amp has been idling for 4 hours, it's not detectable with the LCD-2s. I don't have to prove you're wrong, because my amp does not exhibit the characteristic that you claim it does without you ever having laid eyes on one. You need to prove you're right or put a cork in it.
