goofyvic
- Mar 15, 2011
I use FM frequency noise between radio stations to burn-in. Pardon my ignorance, is that white noise or pink noise? Or it's something else?
I like the look of the leather too. Just curious, do you have a full head of hair or is there some skin up there?
goofyvic said:
If you use white noise to burn in give it some rest from time to time, white noise at high volume played non stop may damage drivers.
Or even better, don't use white noise to burn in, use pink noise.
White noise can potentially damage your drivers.
I've always used music, and quite enjoyed leaving the set-up at night knowing the cans will be enjoying some of my fave artists :¬)
Is there any evidence of noise damaging drivers? Regardless, I'll stick with music.
WA - in your opinion, how much of the creaminess comes back after 200+ hours of burn in?
Is the rev.2 good enough to buy? I met some opinions that it has more trebles and I'm very sensitive to excessive trebles
I can't explore all 1100+ pages here so give me a links with reviews if there're any in this thread.
Thanks![]()
Thanks![]()
The energy distribution from FM interstation noise most closely resembles white noise and if you keep volume levels at or below what you can comfortable listen to, you'll have no problems. I personally like to use music better for burn-in.
Here you go http://en.wikipedia.org/wiki/Colors_of_noise
Radio static is white noise I think.
kwkarth said:
Radio static is NOT the same as white noise, and Wikipedia does NOT say that it is.
