- Dec 4, 2010
I'm finding the clamping force to be decreasing as I use a flower vase/stand to stretch the headband in-between listening session.
Any more thoughts on headband positioning relative to comfort?
Two points/questions on the comfort of the LCD-2 with the leather headband:
Where on your head do you find the most comfortable position for the LCD-2 headband?
When I place the headband over the 'mid-brain' area, midway between the top of my forehead and the top-back corner of my head, I find the back-edge of the headband digs in to my head slightly. Placing the headband over the top and back of my head seems a bit more comfortable for me.
I never had many comfort issues with the metal/foam headband, but I'm finding the clamping force of the leather headband a bit much at times, to the point that I feel it necessary to remove the LCD-2. I never felt I had to take off the metal/foam headband version for that reason. Have you guys found the clamping force of the leather headband LCD-2 reduces with time? Have you found/would you recommend stretching the leather headband to make the LCD-2 more comfortable?
