thecrow
- Oct 18, 2014
That adapter sounds absolutely fine and standard.I just bought a used set of LCD-2 with a date of december 2016.
They have the non leather ear pads, non leather headband, lohb strap, and extended yoke straps.
They come with an extra 4 pin balanced cable but I don't have a balanced amp. I currently only have the Schiit Lyr 2. Is it ok just to use a normal 4pin xlr to trs adapter to use this cable?
And is there anything I should know about these in particular? They will arrive next week. With that date are they the newest design or was there a newer one in 2017?
I never heard about a 2017 update
But if you email audeze, which i did when i bought my late 2016 lcd2, they’ll confirm that. Probably with the range of serial numbers covered by the updates. Or just send them you serial number - i believe you can even verify them on their website
