I stand to be corrected but it’s likely because the amp doesn’t have enough power to drive the LCDs properly, not the other way round.
Well,
I definitley thought of this because it happened to me before when i tried to pair the mad dogs with the shozy alien, at higher volume it distorted badly along the whole spectrum, but in this case just along the high notes when vocals reach this peak, i start hearing zzzzzzzzzz along the high notes, i will try the same song with idsd micro and check the result.
I think that you are playing the LCD-2 to the point that its distorting. I've only used the QP1R in the store and its one of the more powerful DAPs that I've ever heard and I used a HD650 at the time and couldn't get the volume above 70 IIRC before my ears were starting to hurt. While you can check how much power the HD650 and LCD-2 can handle the QP1R is putting out less power at 300ohms (HD650) versus 70ohms (LCD-2) so using the position of the volume knob does not mean much as to how much power each can handle.
Yee thats a nice point, i am not that good in physics, but i will try to get the numbers and check if the output power at high gain will exceed what lcd 2 can handle or not.
Thanks guys
