diamondears
- Oct 1, 2014
Actually I'm in the process of selling that pair of LCD-2's because they are the pre-fazor and didnt have enough impact or speed to the sound. Right now I'm testing out the mrspeakers alpha prime, got until next week before the return policy ends. and if I dont stick with those I will get the fazor lcd-2. The alpha prime I am running in balanced, and the lcd-2 I only had in 1/4in. With this amp, it has two full single ended amps stacked on top of each other inside, so when you use the balanced out you get two amps worth of power and sound, where single ended is just one or the other. I will say it seems to sound a bit stronger, like better imaging, and obviously there is twice the power too, and it just sounds like the way an expensive amp should sound. Single ended is amazing too, but you could tell its a bit better in balanced output. I wouldn't buy this amp if you dont have a balanced connector for your headphones. also at this price range I gained ease of use and flexibility. I have used this amp with hd800s, lcd-2, he-560, denon d5000, and now alpha prime, and it always adapted for them, so I didnt have to consider synergy issues or power issues. I just plug in the headphones and it works as if it was made only for that headphone. Honestly any amp more that 2 grand seems extreme to me, like I can justify what I got for this money, with this amp, but it would be real hard to justify 2-5 times that amount for something that barely improves, and if anything just changes the flavor slightly. Honestly at this point you're just paying for piece of mind, knowing that what you hear through your headphones is pretty much the way those headphones should sound ideally. But if you find an amp that does the job and you like the sound a lot, at a much lower price, then thats just as good really.
My unsolicited advise is---don't let go of your LCD-2 Rev. 2 (non-Fazor). It's perfect in a perfectly neutral amp.
