florence
- Mar 23, 2014
Have anyone used new Anker dongle with iSine20? If someone says when using Tidal it works perfectly with DSP built-in lightning cable, I will order both cable for my S10+.
ill get mine tomorrow. Also for the s10plus! mainly use for spotify. Sometimes UAPP. I have ipad for the cipher but i feel like i want to connect it my s10plus better. Too big to carry ipadmini. If im not mistaken, the eq on the app is actually a memory. If i eq it on ipad, it will carry the eq even on android. That's actually a PLUS!!Have anyone used new Anker dongle with iSine20? If someone says when using Tidal it works perfectly with DSP built-in lightning cable, I will order both cable for my S10+.
Feel free to send me a message when it arrives! I can eq it on an iphone as well and carry it to my android. The only thing I worry whether it works with Tidal or Spotify. Will be waiting for an update then, thanks!ill get mine tomorrow. Also for the s10plus! mainly use for spotify. Sometimes UAPP. I have ipad for the cipher but i feel like i want to connect it my s10plus better. Too big to carry ipadmini. If im not mistaken, the eq on the app is actually a memory. If i eq it on ipad, it will carry the eq even on android. That's actually a PLUS!!
i think someone here already did that and it works fine on android phone. I will assure it again tomorrow!Feel free to send me a message when it arrives! I can eq it on an iphone as well and carry it to my android. The only thing I worry whether it works with Tidal or Spotify. Will be waiting for an update then, thanks!
Yes, works perfectly.Have anyone used new Anker dongle with iSine20? If someone says when using Tidal it works perfectly with DSP built-in lightning cable, I will order both cable for my S10+.
I have a pair of Audeze iSine 20's and the left driver is dead. I've pulled them open to take a look at the diaphragm and I think I can see a tiny hole in the membrane - does anyone have any suggestions on how to repair them or are they kaput?
I have done already; Audeze were helpful for sure, but because my iSine's are out of warranty all they could do was offer a replacement at a discount.They are far from Kaput. Contact Audeze - they have excellent customer service. They will help you out for sure.
I see. That stinks.I have done already; Audeze were helpful for sure, but because my iSine's are out of warranty all they could do was offer a replacement at a discount.
just to share my story here, ive been finding an iem to fit my sound preference of having hd800 for years. Also get used to th600. So basically a pronounced vocals with big soundstage and excellent clarity. I went through Kanas Pro, DM7, Fidue A83, Andromeda. And yep... i returned all of them. All of them have some glaring good reviews talking on good the soundstage and vocals they have. I find nothing much just an average sound that has better clarity here and there. Finally, pulled a trigger on isine20, got cipher cable and tiny bit eq. Yes, this is what im looking for. What else to upgrade except lcdi4 maybe? im just gonna stop here for awhile now since this sounds so good all across genre. Really impressed!
What signature is this? Bright or warm?Filter: ON HSC 12 dB Fc 45 Hz Gain -5 dB
Filter: ON PK Fc 250 Hz Gain -2 dB Q 2
Filter: ON PK Fc 550 Hz Gain -2 dB Q 1
Filter: ON PK Fc 750 Hz Gain -1 dB Q 2
Filter: ON PK Fc 950 Hz Gain -1.8 dB Q 1.2
Filter: ON PK Fc 1100 Hz Gain -3.8 dB Q 1.5
Filter: ON PK Fc 1350 Hz Gain -3 dB Q 1
Filter: ON PK Fc 1600 Hz Gain -2 dB Q 1.5
Filter: ON HSC 18 dB Fc 2400 Hz Gain 8 dB
Filter: ON PK Fc 3850 Hz Gain -3 dB Q 5
Filter: ON PK Fc 6000 Hz Gain -5 dB Q 8
Filter: ON HSC 15 dB Fc 6500 Hz Gain -9 dB
Filter: ON PK Fc 7000 Hz Gain -6 dB Q 6
Filter: ON PK Fc 9100 Hz Gain -2 dB Q 12
Filter: ON PK Fc 8200 Hz Gain -5 dB Q 5
Filter: ON PK Fc 10300 Hz Gain -4 dB Q 15
Filter: ON PK Fc 13000 Hz Gain -4 dB Q 8
Filter: ON PK Fc 15200 Hz Gain -6 dB Q 10
Filter: ON PK Fc 15500 Hz Gain 3 dB Q 15
i will try later tonight. What about bright signature, do you have any?Warm, V-shaped, trying to hide the mid-hump
"Filter: ON HSC 12 dB Fc 45 Hz Gain -5 dB"
Center frequency can be moved back to 10hz or 20hz to reduce sub-bass leak.
