Audeze iSINE 10 & iSINE 20: Audeze releases two new IEM planar magnetic earphones
439 440 441 442 443 444 445 446 447 448
450 451 452 453 454 455 456 457 458 459
  1. twiceboss
    To vocal, clarity, sound separation, sound stage whore out there. This is the eq on v2 cipher. Spoiler; not for basshead
    trellus likes this.
  2. twiceboss
    trellus likes this.
  3. twiceboss
    Is there anything memory wire kind of earhook? the stock is stiff and cant be shaped.
  4. twiceboss
    can i use lightning female to usb c male, for android? i have ipad but i prefer android for my phone.
  5. youngarthur
    dqb4IOuRTBKR4iv+MkS%pw.jpg The iSine20, and the M300, both now very comfortable.Having always used clips, and now headband, I won't be going back to clips.I will post details at the weekend.
    trellus, chellity, M3NTAL and 3 others like this.
  6. twiceboss
    hey, let me know where do you get those headbands, and is it detachable?
  7. stmiller
    Looks comfortable. Hopefully parts aren't difficult to get..
    Looking forward to the DIY
  8. rkw
    The Anker audio adapter works (most generic adapters will not work). I use it with Cipher cable on Android.
    https://www.amazon.com/gp/product/B07R6MKJZH/
    trellus likes this.
  9. gonzfi
    Yo.
    I'm using my lcd i4 with the cipher cable plus an anker lighting to USB-c cable allowing me to pair with my galaxy s9 phone.
    Could I the add a USB-c to USB-a adaptor allowing me to plug straight into my lap top? If so can anyone recommend a suitable adaptor as there are tons of different ones!
    Thanks
    PS posting here because this setup would be exactly the same with an i-sine so hoping someone here might be able to help
  10. twiceboss
  11. twiceboss
    i wonder about the cipher cable of different isine series including lcdi4. Do they carry the same DPS profile for three of them? will it be different if i use lcdi4 cipher cable?
  12. Devodonaldson
    ISine 10/20 same. LCDI4 different. I have both
    trellus likes this.
  13. twiceboss
    so, lcdi4 has the same 2 pin connection right? so we can use lcdi4 DSP on isine 20? how does it sound?
  14. Devodonaldson
    No. I mean I have both headphones and both cipher cables. They are tuned differently and do not sound good with the other cable. ISine cipher more highly eq'd than LCDi4 cipher. LCDi4 doesn't sound right with iSine cipher either
    trellus likes this.
  15. twiceboss
    Oh! Good to know. Thank you!
    With your both isine20 and lcdi4. Can you eq your 20 with my current fav eq:
    125hz -1
    250hz -2
    500hz -1
    4khz +1
    8khz +1
    16khz +1
    And compare it with lcdi4. Whats the sound signature difference between them? Much appreciated.
