You should confirm with Audeze customer service what the right size connector is for the iSine LX. Otherwise you’ll just have a guessing game going on. For example I read it’s .78mm with a notch.
Preamp: -7 dB
Filter 1: ON LS Fc 120 Hz Gain 7 dB
Filter 2: ON PK Fc 1000 Hz Gain -6 dB Q .9
Filter 3: ON PK Fc 4000 Hz Gain 6 dB Q .1
Glad you like them, Try these, they're better:
Preamp: -8 dB
Filter 1: ON LS Fc 120 Hz Gain 3 dB
Filter 2: ON PK Fc 250 Hz Gain -3.5 dB Q 1
Filter 3: ON PK Fc 1000 Hz Gain -8.5 dB Q 1.5
Filter 4: ON PK Fc 4000 Hz Gain 7.5 dB Q .4
Thank you I certainly will give them a go after work tomorrow. I picked up an AK70 Mk2 from richer sounds on the way home from work yesterday the isines are sounding great out of that without EQ but on PC that APO EQ is a absolute godsend thanks.
Thanks man. I contacted Audeze they said they will get a new cable sent out. In the mean time I was messing with this cable and it I twist and pressure the plastic splitter for the cables the left ear piece will kick in.
It’s like when you plug your headphones into an amp/dac and sometimes when you’re using a cheap connector it will cut out if you move the position except on this case it’s always out and cuts in. Still they sound great when they’re both on, now just to wait for the cable
This post is related to something I was wondering. Pardon if you've answered this before.
I've expressed my happiness with the Reveal plug in earlier; i use it in Foobar. But I'm considering another player. Roon has piqued my interest.
I may be wrong, but I understand that the Audeze Roon offering for the iSine is different than the Reveal VST plugin. If this is right, as far as audio playback fidelity is concerned, would you say the audible end result of the two are identical? Or would you lean one way or the other, and which way?
Much Thanx @KMann. Likewise to anyone with experience with the two; Roon and other music player with the Reveal plugin active.
There is a Audeze Roon thread where I have shared the information. The short answer is both Reveal and Roon presets have the same frequency response/tuning but in Roon we also offer linear phase filter option which has the potential to sound more transparent and improve imaging. Reveal uses zero latency filters which are close to analogue filters, the option is also available in Roon and they should sound identical. I will be happy to answer any follow up questions on the Roon or Reveal threads.
Kmann, I’m just astounded with your patience in the community and appreciate how you handle things. Especially as such trollish behavior seen recently has discouraged interactions from voluntary experts in other Audio forums that I’ve seen (referencing a guitar gear board).
You’re a true blessing to head fi and I hope you know how much your presence is appreciated, though it may sometimes not be explicitly displayed day to day.
The linear filters are processor intensive and require a efficient DSP engine, it will take a significant effort to do that, if we see enough demand we may consider it.
I know this is off topic, but I must thank you for alerting us to this. Never saw it before. Full size SD? 7V balanced swing? (Caveat, no load. Hope that doesn't slack/droop too much with the iSine20 as load). That 'new tech' et al? I'm all over this. Can't await to give it a try @ Can Jam NYC in a little over a week. I think Mrs. m8o will have something to bitch about soon; ie another audio related expendature. Lol
