Astell & Kern SR15: A&norma Impressions & Reviews
Discussion in 'Portable Source Gear' started by pitch_black, Jul 29, 2018.
84 85 86 87 88 89 90 91 92 93
95 96 97 98 99 100 101 102 103 104
  1. nicodem
    Same question from my side. This is really annoying.
    JeroenTop likes this.
  2. 329161
    So just checked again and there doesn't appear to be any cue file support at all in the sr15. It was supported in older Ak players. Any support in this thread anymore?
  3. JasonNYC
    There is cue support in the SR15. The post you quoted says where it can be found. Cue support was also discussed in length earlier in this thread months ago
    Astell&Kern Stay updated on Astell&Kern at their sponsor page on Head-Fi.
    https://www.facebook.com/astellnkern/ https://twitter.com/astell_kern https://instagram.com/astellnkern https://us.astellnkern.com support.inc@iriver.com
    buonassi likes this.
  4. JasonNYC
    Roon was targeted for the end of 2018, but I had commented on here that with the holidays and backlog of Roon certifications that it would be pushed. Still coming soon. Once we have a more concrete date, I will post.
  5. chasfs
    Lyrics dont work. I used foobar2000 to load lyrics into lra files in the same directory as the flac files - no lyrics in SR15. Then into LYRICS tags - still no lyrics in SR15. Does anyone have this working?
  6. 329161
    Ok, so the post I quoted was originally mine. I was mistaken. I just checked again in album, folder, and playlist views, cue files don't appear to function in any of them. I just searched the word "cue" in this thread and the only posts that came up were my last 2 and yours quoting me. Thanks for replying though
  7. JasonNYC
    I apologize. I was sure it was this thread, but it must have been discussed in one of the other player threads.
    Currently, you can access Cue sheets in the Album view by pressing the "Cue" icon at the top once you are in album view. There has been some requests to expand Cue functionality and it is being looked into by our dev team. If you have some specific recommendations/requests regarding Cus support, I will pass them onto the dev team to look into implementing in a future firmware update.
  8. JeroenTop
    Thanks. Fingers crossed
  9. 329161
    Thanks for that. I never saw that icon before. My apologies.
  10. -Kenny-
    Is it me or does the sideloaded tidal app sound better than the stock tidal app?
    I never used the sideloaded tidal app before, but tonight was forced to, because the stock tidal doesn't want to play half of my files. It just says: "the record label doesn't allow this track to be streamed"
  11. gunwale
    I always power off my phone while playing tidal.
    One day it corrupted my whole tidal open app... I couldn't play anything and all my offline files were gone.
    I restarted a few times and still it didn't work. I did a reset playlist restarted again and it worked.
  12. Jprod
    I have had it for a few days. Qobuz integration is not great imo. Too buggy ( that’s not the sr 15s fault ).
    Also to my ears tidal sounds better on the sr 15. On my desktop setup (woo wa7 ) I give the nod to Qobuz.
  13. Vincentaria
    Hi Jason, is there any feedback from the team of lastfm scrobble support? Thanks.
  14. biscottino
    I have qobuz hires and installed in memory about 40gb of album, about 150, there is no player problem and the sound is really fantastic, sure to have the latest version of the Qobuz app?
  15. Jprod
    Yes. I believe it is 5.1.6 ?
