Is there a way that the player sorts artists by album artist? I really don't like to have a list of. All. Artists that contributed to a compilation
Astell & Kern SR15: A&norma Impressions & Reviews
- Thread starter pitch_black
JeremyLaurenson
- Jan 3, 2011
Any status on the external playlists issue. Not sure how often I should bother you.The latest firmware update contains bug fixes and OS optimizations. I don't have any specifics on what bug fixes there were.
cirodts
- Jan 27, 2016
In your opinion, does it have a better sound sr 15 norma than balanced with headphones or connected to a mojo with headphones?
Has anyone tried?
Has anyone tried?
6 - 8 hours is typical for the SR15
deal breaker...
Tidal just released a new app update today - v. 2.11.5. No info on what it fixes, but if someone could please try the new version and let me know if you are still experiencing the same issues.
Only been able to listen for about 45 minutes in offline mode, but so far no issues. Hopefully it’s been fixed!
abitdeef
Formerly known as ihatepopupads
- Oct 30, 2003
deal breaker...
That’s not bad for the quality of the amp, the speed of the UI and the size of AK SR15. Unless you go with a much bigger dap, or one with less power like a small cowon and a decent size battery, or a Sony with class D- you’re not going to do much better.
My girlfriend has been having that exact same tidal issue for months on her phone. Tidal support made her jump through a whole bunch of hoops, e-mailing back and forth for weeks without any results. She ended up cancelling her tidal subscription and getting spotify.
I never had an issue on my phone though. Never tried offline on the sr15 yet. I was thinking it's a combination of tidal with certain versions of android that causes some issues.
Excellent. Please let me know if you do experience any further issues.Only been able to listen for about 45 minutes in offline mode, but so far no issues. Hopefully it’s been fixed!
Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
Well its 6-8 h at best. SE, no screen etc. . Most User will get 5-6h. So you have to charge every day. (For some it doesn´t even last a whole day if they travel a lot).
cirodts
- Jan 27, 2016
I thought, better ak sr15 balanced or connected to the mojo?
- May 7, 2017
To my ears SR15 balanced is good enough and don’t need to connect to Mojo.
abitdeef
- Oct 30, 2003
If you’re going to be driver harder to drive cans mojo of course. And of course it’s got a wider sound stage. If you have normal ohm headphones under 300 ohm, or iems you can have one unit that sounds great without stacking.
With mojo of course you need a dap, and because it’s not cheap why spend 700 dollars on a dap if you’re going use it as a transport? I mean it would make a great transport, I just don’t see the need.
Bottom line, yes mojo sounds a bit better- it’s got more power and a great dac. But sr15 sounds great and it’s all in one
cirodts
- Jan 27, 2016
Thanks for the answers, I currently use hiby r3-mojo but if instead of the r3 we put sr15 will be a better source, but if sr15 in balance is higher than the mojo would be better.
ThomasHK
- Aug 12, 2013
Tidal 2.11.5 solved the issues the app had. Was android wide, not just AK.
The balanced out is so good on this thing. For people looking for a low noise DAP, this balanced basically has none.
SR15 actually hisses a little with my 334 and audibly so on andromedas
Cutting-edge artisanal in-ear monitors for discerning listeners. Proudly designed and manufactured in Singapore.
Stay updated on Subtonic Audio at their sponsor profile on Head-Fi.
