Astell & Kern KANN - DAP with Massive Storage & Battery
Discussion in 'Portable Source Gear' started by Levanter, Apr 4, 2017.
82 83 84 85 86 87 88 89 90 91
93 94 95 96 97 98 99 100 101 102
  1. Mr. Thompson
    I'm no digital audio expert. I have managed to avoid it for the most part and only plug into the digits for convenience. Tinkering with filters sounds interesting. When I have the time I'll read up on it. There are a whole lot of bunches of albums here and a couple short of 800 CDs. You get the picture.
    I have spent a few evenings with my ancient SR71 plugged in between the Kann and the Etymotics. All is well, the resonance missing with the internal amp is back. Same results using the Holmes Powell amp and Grado HP-2s. Thoughts?
  2. loplop
    My findings, as well. The internal amp is a bit dry with some headphones. I am currently using an ALO Continental V2 or my vintage Sansui receiver when I’d like to sweeten the sound of the KANN.
    It’s possibly a load/headphone thing. I’m curious to try my LCD2C’s on the KANN when they arrive, as they should already be a bit on the lush side, which may temper the KANN’s tendencies a bit.
    I want to mention that I still use the internal amp, as it’s obviously the most convenient when I’m the go. It’s very capable and certainly doesn’t sound *bad*. But, when I have more time/space (at home, or in my office), I find it preferable to use the KANNs excellent line out (which doesn’t seem to pass through the ‘dry’ character) to an external amp.
    Luckyleo likes this.
  3. jrbgarcia
    I got those 2 daps first is n5ii then x7ii.. N5ii has a nice midrange neutral to warm, black background with no hiss... Imaging and seperation and resolution beats most of the daps especially when you are into musical.. On the x7ii.. Midrange imaging is stunning compared to most daps when I auditioned them at egghead for 2 hours while choosing... It beats the ak kann and ak70 mk2 in most areas most specially in imaging and midrange quality.. But x7ii is better for me since it is fast.. Transparent... Nice seperation though background has glare.. They are not far from each other but for mids I prefer the x7ii for instrumental n5ii.. Overall I would pick the x7ii due to its neutral reference sound sig.. Just sharing.. My words are not enough feel free to pm me
    -some guy comparing the kann and the x7ii LOOOOOOOOOOOOL
  4. loplop
    Are you suggesting the x7ii has “glare” in its presentation? I associate glare with poor digital reproduction, and am very sensitive to it (perhaps because I grew up in the analog era). That would kill the x7ii for me.
    I find no glare in the KANN. It has its weaknesses, but luckily glare is not one.
  5. jrbgarcia
    not my words, some guy in an audiophile group
  6. thor777
    I noticed that I'm not able to adjust the volume using the wheel while the screen is off and in DAC mode. Volume wheel works fine while in player mode when the screen is off. The firmware is 1.05CM. Is anyone else experiencing the same thing? If so, is this intended behavior?
  7. m8o
    To any mfg. rep. that reads this. Could you confirm that a Kann or few will be @ Can Jam NYC next wekend to audition?
    Thanx
  8. Shetzu
  9. m8o
    Tho, not Tyl's, John Grandberg's.
  10. Shetzu
    Thanks Corrected my post.
  11. JasonNYC
    @m8o Our NYC dealer Audio46 will have demo units of the KANN, AK70 MK II and SP1000 available for listening at the show.
    Astell&Kern Stay updated on Astell&Kern at their sponsor page on Head-Fi.
    https://www.facebook.com/astellnkern/ https://twitter.com/astell_kern https://instagram.com/astellnkern https://us.astellnkern.com support.inc@iriver.com
  12. thor777
    @JasonNYC Hi Jason, can you tell me if this is intended behavior? noticed that I'm not able to adjust the volume using the wheel while the screen is off and in DAC mode. Volume wheel works fine while in player mode when the screen is off. The firmware is 1.05CM and lock function is disabled.
    Thanks.
  13. JasonNYC
    @thor777
    Volume control in USB DAC mode only works when the screen is on. It does not work when the screen is turned off and in USB DAC mode. Is your volume control not working when the screen is turned on in USB DAC mode?
  14. thor777
    @JasonNYC Thank you for your reply. My unit is working as intended then. The volume works fine in DAC mode when screen is on.
  15. project86 Contributor
    Thanks for posting the link! I came here to post it myself, and now I don't have to.
    I really enjoyed evaluating the KANN, and I hope that came through in the writeup. It's not the ideal player for everyone, but has a lot going for it overall. I often find myself reaching for it at home... when I'm too lazy to fire up the big system. In fact I'm using it right now with a Focal Elex, relaxing to a Sober Rob album, and quite enjoying the result.
    Redwingnine likes this.
