Astell & Kern KANN - DAP with Massive Storage & Battery
- Thread starter Levanter
Miniculthero
- Apr 3, 2014
Can anyone tell me if the kann is compatible with the new 1tb ssd sandisk
DaYooper
I'm pretty sure the Kaan can do OTG from a SSD but try it and see. I have a 1tb SD card in mine and got away with it along with the 512GB microSD. But I loaded it on the computer then put it in the Kaan. After turning it on it went through a looooong scan but then it was ok. It's a crap shoot with 1tb stuff and this player.
P.S. Make sure you format the card in the dap before loading it.
aroth897
How do you feel like the Kann holds up as portable player in 2020 . How does it hold up again portable amp/dacs such as the monolith thx aaa portable or idsd black label? I understand these options lack the storage but they easily attach to phones
Shmid
Has anyone here tried the Kann with the Diana V2?
I'm wondering if this has enough juice to run it sufficiently or should I wait to purchase the Alpha?
I'm currently using KANN with Diana V1, and when running balanced I was surprised but doesn't really struggle with them. And also KANN sounds better on Balanced output ot my ear on Diana.
Luckily I was able to sell Kann(kunt) on gumtree uk for £330, because I knew AK will never release a fix for their damn firmware.
Gerryhatrick
- Nov 9, 2015
Hi all
picked up a used Kann today: delighted! Tried AK Connect and picked up my server no problem, but attempting to play tracks threw up an “illegal mime type error” no idea what this is and Google comes up with nothing. Can’t find anything on this thread...16 or 24 bit, same problem.
Help much appreciated
Kann software is unfortunately not polished and there will be no updates, also hardware (cpu/ram) is struggling a bit occasionally. Sound though is good, I have just purchased Fiio M15, and have to tell software is way better, sound is very similar, not that much of a difference, although M15 needs 100h+ to shine.
Try to do factory reset, it might helpHi all
Gerryhatrick
- Nov 9, 2015
Seems a little extreme!
R7photo
- Apr 28, 2017
just giving Kann some love, I believe Kann is going to be a all time rare jewel because of the sound quality
She she’s kinda got some slow but stable software and minor other issues but sq is not one of them
Please note , you need correct pairing and you enter sublime territory ,
Smooth liquid mids , and a velvety sound,, tube like airy soundstage,,
2 gain options,,
eq, useless but AK engineers, ( sound engineers), tune this dap to a natural sounding dap, close your eyes and enjoy
My iem, again pairing matters, right seal tip,, including keeping your ear canal clean, makes more sq adjustment, than mild eq,
My dap, is rich deep tubelike when needed and airy lush, simbent when needed
I will never sell her,
Just given dap some love
2 gain options,,
thor777
- Apr 9, 2010
Did anyone have issue with their Kann not powering on? Mine was working fine yesterday. Shut it down for the night and today it won't power on. Tried plugging in a charging cable but no charging icon.
R7photo
- Apr 28, 2017
2 gain options,,
My Kann got hot after several hours listening, it turn off but after cooled it turn back on, I think this happened one time
mine stopped one time after it got hot,, but after it cooled down it work back fine,, only happened one timeDid anyone have issue with their Kann not powering on? Mine was working fine yesterday. Shut it down for the night and today it won't power on. Tried plugging in a charging cable but no charging icon.
thor777
- Apr 9, 2010
ok, thanks for the reply
Gerryhatrick
- Nov 9, 2015
Apologies if this has been asked before but it seems like this should be possible: When selecting album should all content (internal storage, SD card and mSD card be displayed?
In my case with SD card and mSD card inserted if I select album or artist only the contents of the SD card are shown. I can only see the content of the mSD card by selecting “folder/mSD”.
Am I missing something bleeding obvious to anyone with a reasonable IQ who has read the manual?
