steffi
- Nov 15, 2005
Is there a way to create an actual sub folder in ATP? Ie. One that isn't off the root? It appears you cannot select the parent and have the sub folder created under it.
Check your cable and USB hub, it may not be getting enough power.
This thing is going to look incredible once it ages, develops its patina . . .
I received my 380 amp yesterday and listened to it a bit longer than I meant to last night. My initial impression is that is takes my custom Laylas to an all new level.
Why i heard no improvement when i tested it in the shop ? slightly worse bass.
Strange.
Since you are the one who claim that, could you tell me what is improve? Dynamics? slam? Bass? High ? Mid? Stereo? rhythm -Speed? Air-ambient?
What did the AMP improve over AK380 alone?
Do you own stocks in AK?
Single end of balanced? The power from the single end side of the amp is actually WEAKER than stock.
I was using my custom Laylas via the balanced connection on the amp. The more immediate difference to my ears was the separation, which seems to allow details more room to be truer and more accurate.
The Grado GH-1's don't seem to show a much of a difference with or without the amp.
That's all the comparisons I've been able to do so far.
For the benefit of others, from Google Translate:
Ha! Just you wait till it turns green.![]()
