Thanks for the insight. Looking forward to this very much, just joined the drop @ MassDrop for the CA Lyra IIs, can't wait to pair it with the AP80.
Also,
Cosmetic question: based on Bad Guy Good Audio Reviews the device shows markings for each input (it says in big white letters "Type C" under the port for example). My question is will the final units have the same? Or is the whole device sort of inconspicuous? I personally would prefer no writing anywhere, I think most users will know which port is which
Yep, but there were some complains about inserting microSD card right... which caused some damage. It means that at least microSD card slot should be labeled with the corresponding icon
