AP80 - Hidizs next portable Hi-Res music player
Discussion in 'Portable Source Gear' started by IryxBRO, Apr 24, 2018.
20 21 22 23 24 25 26 27 28 29
31 32 33 34 35 36 37 38 39 40
  1. kenloveme
    @ExpatinJapan Thanks for the info and feedbacks, so we can still adjust the small tweaks in the future! Glad to know everything is working well so far! :D I am also looking forward for your pro review! haha
    ExpatinJapan likes this.
  2. kenloveme
    @Tweety 99 Thanks for joining and for your support! :D, we wanted to match high portability with hi-res audio on the AP80 so it will definitely give you a nice blast in time with a glimpse of modernity :wink:.
    Tweety 99 likes this.
  3. kenloveme
    @abitdeef Since the AP80 uses HiBy OS, it will constantly improve so it is already playing on a different league than the M0. :wink:
    TheRH likes this.
  4. kenloveme
    @twister6 Looking forward for it! I'm curious about your first impressions on the AP80 :D
  5. ExpatinJapan
    Me too.
    :ksc75smile:
  6. kenloveme
    @Zeo-Gold92 Thank you for backing up our AP80! :D, I invite you to read about @IryxBRO interesting review here on testing different IEMs with the AP80 as he also used the Seeds earphones :)
  7. kenloveme
    @Spon Welcome to Head-fi and many thanks for choosing the AP80 as your first DAP experience! :D. It will not let you go unnoticed, you can be sure of it :D.
    If you are looking for new earbuds, you can also check @IryxBRO review here, he tested different earphones that are a good match for the AP80 like the Seeds or Dawnwood ST08 :)
  8. kenloveme
    @Luhar Like @IryxBRO said, we received complains about the right way of inserting the MicroSD card so we thought it was better to be transparent and clear on the labels indication. You know, just in case there are new hi-fi beginners, it can always help them :wink:
    Luhar likes this.
  9. kenloveme
    @Zachik Perfect! :D Thanks and welcome to the AP80 Brotherhood! :D ahah
    Zachik likes this.
  10. IryxBRO
    Wireless interfaces (bluetooth in case of AP80) can be disabled by the corresponding toggle in drop down menu. Step counter doesn't seem to be working unless you would run this app.
    Yep, I've also checked with Hidizs Sonata DH1000 - work well. Not sure what you mean "fixed".
    300Ohm might be a heavy load for AP80. It might still sound good but it would require more power for better dynamics and speed. I would rather use AP80 in pair with some headphone amp to get the most of HD600 potential.
    TheRH likes this.
  11. kenloveme
    @MisterMudd Thanks for joining us! :D We are super excited to get all your feedbacks and you will definitely enjoy your gift! :D
  12. kenloveme
    @abitdeef Yes but you are waiting in anticipation, so it will make you even happier when you will receive it! :D
  13. okinear
    @ kenloveme,
    What about a short FAQ on KS too?
    The comments section is rather quiet there (compare to this thread) but the very same questions keep coming again and again...
  14. kenloveme
    @okinear I think it is a great idea! I will take care of it asap! :D Thanks for the suggestion!
  15. kenloveme
    Like @IryxBRO did, I thought it would be interesting to show to you all the possible swipe shortcuts you could do on the AP80 to make your experience easier. :D, So here is the video:
    TOUCHSCREEN GESTURES AND SHORTCUTS :
    Any screen:
    If you swipe down from the top screen, you will be able to turn on and off several features such as BT, set the Gain to Low or High, DAC in or out and also enable line out.
    By swiping up from the bottom of the screen, you can quickly adjust the brightness of the screen, volume of the song you are currently playing and also pause/play change tracks.
    To unlock the screen when you are listening to a song just swipe up from the center of the screen.
    Main Menu:
    When you are on the Main Menu and you select for instance, System settings, by swiping to the right you can go back to the Main Menu screen. This will avoid you struggling on clicking on the small arrow icon on the top left of the screen to go back to the Main Menu.
    So always remember to swipe to the right to go back to the Main Menu :D. This shortcut only works when you are going using the Step counter, System settings and FM.
    Player screen:
    If you swipe to the right, you can update your song list database, have access to the MSEB, Equalizer, enable/disable Bluetooth, change the play settings or go back to the Main Menu screen by pressing on Exit. However you can also click on the Hidizs logo to go back to the Main Menu screen.
    By swiping to the left while you are on the Player screen, It enables you to get to the screen where your current track is playing.
    From the Player screen, there are 3 interesting icons on the top of the screen:
    • The first one will show you all the songs on your AP80, you can check them in different sorting categories like Album, Artists and Genre
    • The second one will enable you to listen to your songs according to the playlists you’ve created and favored
    • The third one takes you to the screen where your current track is playing
    Current song playing screen:
    From this screen, you can of course fast-forward, rewind, pause/play. You can favor the current song you are playing to put it as favorite with the heart icon on the bottom right. You can also change the play type on the bottom left. By clicking on the 3 dots on the bottom right, you can do a wide range of things such as access to the EQ, add the song to a playlist , look at the properties…
    TheRH, j4100 and xuyiguanyinsi like this.
