OmniscientNihilist
ya your micro sd card is most likely a fake. you got ripped off.
second possibility would be your tags are not reading properly so you should switch to tagscanner program. https://www.xdlab.ru/en/
get this card instead
i would stay away from sandisk and also patriot. alot of the sandisk on amazon are fake. and the patriots have a bug with the ap80 where u cant copy files over the usb cable
after you get a working sd card you can follow these tips for further helps
https://www.head-fi.org/threads/ap8...es-music-player.878141/page-221#post-15250661
