It really is about what you're looking for from a DAC.
My DAC beats the DFR in bit depth, sampling rate, cost and DSD playback. It loses in output impedance (it has a higher output impedance than the DFR), battery drain and size. (DFR is smaller than the mDSD, but the mDSD is not big at all.)
You mean on the amp side? You'd have to check out a comparison / review.
The extra draw on the mDSD is from the XMOS controller, which gives you 32/384 instead of 24/96, but it doesn't really tell you about relative amp power between the two devices.
But native DSD is a beautiful thing. Michael Jackson - Thriller SACD is a beautiful thing when played in native DSD.
As of now, I don't believe I can hear a clear difference past 16/44.1 files, so I'm okay without getting 32/384. Maybe once I can get ahold of more "hi-def" music, I can make a better assessment.
In any event, it looks like the mDSD is a better dac than the DFB, but I need the extra juice from the Red. All my headphones are full-size, and my ZMF Ori needs the extra power.
Thanks for sharing this information, however. I'll keep it in mind if I need another portable DAC.
Try listening to a SACD version and a HD FLAC version of the same album. Another reason to go DSD is that the masters for SACD are usually of better quality, if not the same quality as the PCM / FLAC masters.
This only helps if you're into the music that made it onto SACD, which is quite limited.
Buying a S7 and chord mojo, is there anyway to charge the Samsung S7 while using the Mojo via usb otg cable? Like some sort of way to split the samsung port to enable charging and to connect to the mojo. I've been looking around the net for solutions but can't seem to find anything.
