Percival
- Jul 18, 2008
Its possible that there is some kind of DSP or post processing going on.
Or it could be psychological - like an awful lot of perceived differences in sound reproduction.
i don't know when i play the same song 192/24 bit from the iPod using onkyo player it sounds different than when i use uapp on android when connected to idsd, with iPod i don't know why i find more warmth in the sound
That is because software DOES make a difference and you hear it. Believe your ears, not what you are told!
By that logic, we should not believe you telling us that software makes a difference.
Personally, I am more inclined to believe something if it has objective, reproducible evidence to back it up. I'm justoddscientific that way.
Sir Knight, until the 1600s there was no scientific explanation for the colour white. Newton offered the first plausibe explanation, which was questioned by people like Goethe until the early 19th Century. Does it mean that until that day people should doubt the evidence of their senses, i.e. the existence of the colour white simply because scientists could not explain it?
Psycho-acoustics is not well understood. Most of the best and most thorough research in psycho-acoustics occurred in the 1930s, for the U.S. Navy Sonar and anti-submarine warfare programs.
Exactly how the human brain perceives sounds (plural) at various frequencies and volume levels, is a work in progress.
So too are the testing methods by which any theories are tested. ABX, for instance, is largely useless.
I ask the army of ABX zealots to please refrain from attacking me, I won't engage you any further so try to save it, especially since this whole thing is now off-topic for the thread.
It depends on the USB DAC.
The hardware volume keys of a Galaxy S3 / Note3 can modify the volume of the active audio stream of HibyMusic player when driving an ODAC or a C-Media CM119 chipset-based sound card.
When driving a FiiO E17 or a XMOS USB 384K/32bit PCM5102, they cannot.
The USB descriptors of ODAC, C-Media CM119 chipset-based sound card, FiiO E17 and XMOS USB 384K/32bit PCM5102 can be found at the following link:
https://docs.google.com/file/d/0B3XYy1FuzDUeZXNUYmF2SG5WNWs/edit?pli=1
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/5760#post_11076260
