DJScope
- Mar 24, 2014
Does anyone know if you can use your android phone (note 3) paired with an astel and kern player, specially the new AK120 ii?
Why? The AK120 is a DAP already...
Isn't the AK120 MKII an Android device?
Spotify
Android-based perhaps, but like a bunch of other Android-based devices, they only used that as the starting point for the firmware. It doesn't necessarily mean that it actually works like an Android competitor to the iPod Touch. Even the bulky DX100, which uses an OS that is nearly unchanged from whatever version of Android that is, doesn't work the same way as a Galaxy S player. You have to hook it up to install player apps, instead of accessing the Google Play Store directly (others can't even get apps).
I do however see your prior point about the AK120 being a DAP already - considering you can load two mciroSD cards in there on top of its internal 32gb memory, I also cannot see the need for Spotify. Then again, half my music probably isn't even on Spotify.
I've got an Audioquest Dragonfly and would love to use it with my Nexus 5 that's running L. What exactly do I need to get this working? I know I need a USB OTG cable, does any otg cable like this one work?
I was also wondering if I'm going to need a portable amp with it or if the Dragonfly will be enough.
Originally Posted by m-i-c-k-e-y /img/forum/go_quote.gif
What's interesting with Geek Out (like Dragonfly) is that it has indicator lights.
When playing with Neutron, Poweramp, BS Player indicator lights are always 48K, unlike UAPP it reflects the sample rate correctly.
Does these mean Neutron, Poweramp, BS Player (or other players) outputs only at 48K regardless what is the source's sample rate??
With that in mind, I believe the cable will be the problem. Does anyone make a OTG cable from the USB port on the phone to a type B USB at the iDSD?
Good point! I just ordered a AK100 II new model.
Well, the AK 100 II is a USB DAC, so maybe that will work. I'll let you know.
I'm currently running Galaxy S5 + E18.
Also, the AK100 II supports Bluetooth and WiFi audio streaming, so maybe those can be used as well.
Greetings,
Casper
It looks like just a heavily skinned Android. As long as it is using Android as a base then it will still be capable of every that Android can do. Don't forget that Android is open source and is quite easily modifiable because of that fact. It's not about the player app, it's about the ability to stream music through the audio out like every other Android device does. The only difference is that the AK 120 uses extremely overpriced and capable DAC and amp section that normal Android devices don't have. It's probably as simple as installing Spotify as a standard app and running it via WiFi. If it's block from doing so, you could change the permissions and allow it to install all the apps.
Yes.
When a micro USB OTG plug (i.e. pin 4 connected to pin 5) of such a cable is inserted into a USB On The Go-capable Android device like the Nexus 5, the Android device is configured to USB host mode, able to drive a USB peripheral like a USB mouse or a USB DAC.
PC or Mac > USB audio out >> regular USB cable >> DragonFly >> headphones
Nexus 5 > USB audio out >> USB OTG adapter cable >> DragonFly >> headphones
It depends on your headphones.
People used to select an amp allowing the best matching / synergy with their headphones.
http://www.head-fi.org/t/617241/audioquest-dragonfly-review-affordable-outstanding-tiny-dac-amp
Thanks for answering! I'm pretty new at this, and trying to learn as much as possible by my self but information from people like you makes it much easier.
I'm currently using Sony MDR-V6 / Audio-Technica ATH-M50 headphones. So I wasn't sure if I needed to add an amp in so it'll be
Nexus 5 > USB audio out >> USB OTG adapter cable >> DragonFly >> AMP >> headphones
I've also been looking at the FiiO E18 DAC & AMP. Although I'm not sure how well it works with the Nexus 5 on Android L.
If I was to get it would it be better to go
Nexus 5 > USB audio out >> USB OTG adapter cable >> DragonFly >> FiiO E18 >> headphones
or just
Nexus 5 > USB audio out >> USB OTG adapter cable >> FiiO E18 >> headphones
and drop the DragonFly since the Fiio E18 seems to have a dac built into it?
Google | Nexus5(CM11 4.4.2) | |
Hi Dark,
I've owned a E18 for a couple of weeks now.
I combine it with my Galaxy 5S and own a pair of Pioneer DJE-2000 IEM, AKG 551 and Beyerdynamic DT880 (250 Ohm).
The E18 delivers great for me. Works as PC/MAC DAC+Amp, Android DAC+Amp and iPad DAC+Amp (with camera connect kit).
It can also function as an external battery pack for you phone to recharge it.
On the FIIO site you can see that it runs with your Nexus 5.
http://www.fiio.net/products/index.aspx?ID=100000049935442&MenuID=105026002
Google Nexus5(CM11 4.4.2)
(specifications page of the E18)
I've got "the" Android setup running ...
My Android Setup, in detail:
- Samsung Galaxy S5
- 128 GB microSD
- FIIO E18 (via USB OTG, DAC + AMP)
- PowerAmp Pro app for listening
- iSyncr (bought full version), this has a PC and Android part/module.
- iTunes + other + Loss-less CD conversions + FLAC Downloads
Total cost for all this great software: 3.49€ + 3.99€ + 2.99€ .... all bases covered for 10.47€!!
I hope this can help,
Casper
