capeterson17
- Mar 5, 2013
Thanks for the help guys. I can still return the dragonfly so we are all good.
Dragonfly's tas1020 usb streaming controller will never work with android so you're out of luck.
I am using a Dragonfly with my Xperia Z without problems...(with USBAPP)
Hello everybody
galaxy S4 + OTG + HiFimeDIY Sabre
Is there´s any idea for simultaneous DAC + charging phone - I would be so grateful.![]()
May be it´s posible with an 100K Ohm resistor across the ID/Sense (pin / pin 4) and Ground (pin 5) ? Any experience?
Originally posted by Wigwamclan : Can anyone point me towards an inexpensive mini-micro-standard OTG Y cable?
Hello, i bought this:
http://cgi.ebay.fr/ws/eBayISAPI.dll?ViewItem&item=400548410241&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
and i connect it my Fiio e7 (in order) then to the galaxy note 2, and when i try to listen to music, the sound come out from the phone speaker.
Why ?
It is the good cable ?
Thanks a lot. Relief to know that it works both dac and amp on my galaxy s3. Since people say galaxy s3 has to be rooted or something like that to enable usb audio. Now things have been clear, I guess they enabled it in the jellybean update.You can certainly use it as a chain but if you want to use the DAC and Amp separately/independently you might not be able to. Something you should contact JDS about and word that very carefully. If you want to use it as a chain then you're in business as that's the common use.
Okay guys, I have some pretty exciting news to share: it looks like there's a way to share external hard drives with an Android device and have the files stored on the hard drive play through USBPP and output to a USB DAC!!! I just got it working and wanted to share! (If someone has already done this before, then please excuse my excitement-- but this seems to me to be a method of getting access to vast quantities of music at high quality while on the go, and unless I've missed it this hasn't been accomplished yet).
Current Setup: FLAC files on a WD 1TB external HD >>[standard USB]>> Ravpower FileHub >>[WiFi connection]>> Nexus 7 Tablet (USBPP & MobileFun) >>[micro-to-mini USB OTG cable]>> iBasso D-Zero DAC/amp >> ASG-2 IEMs
I've been trying to get the app's dev to confirm this; are you sure? I was hoping that I could dongle a usb dac off my new Nexus 5 while streaming a TB of flacs off of one of the new wireless hard drives like the Seagate.
