m-i-c-k-e-y
What I have seen only is form Venture Craft.
Link: http://www.amazon.com/microUSB-Digital-Short-Cable/dp/B00B1NSW8C
I can confirm the GS4 doesn´t work with my ODAC, which worked beautifuly with the GS3.
Very bad move from Samsung. Had I known before, I wouldn´t have bought this phone. If anoybody has a way to let them know how they screwed this up. Maybe there´s hope that they can fix this.
Can someone please explain how a USB cable can result in better sound?
From: [Mod Edit: URL removed. Site belongs to a banned member.]
"Anyway, as you can imagine the most important thing is whether or not it actually sounds any different or better than the cheap cable I have. In the past I found that headphone cables make the most obvious difference, then analog interconnects and finally digital cables. That being said the difference this cable made was obvious from the off. It had a typical warm copper sound to it that was very mellow and smooth. It helps tame a little bit of treble glare if presence in the earphone like with the Fischer Audio DBA-02 or Rhapsodio R^2 and gives a nice smooth, buttery tone to the midrange. I also found the old iBasso cable I used to take a bit of life out of the DACs that I knew and loved. At the time I thought maybe Android was just not that good a transport but I can now conclude that the cable was just getting in the way and that this turns my Android rig into one that is truly amazing."
But just remember, that there are never any bits travelling across metal conductors. There are always all the same good old electrical impulses that do the trick. And as such, they have two key characteristics that are later used to decipher them into "bits": their magnitude and their timing.
