Best DDC/USB treatment option will be situational as some DACs will perform better in different setups to others.It looks like it was the Chord Asio 1.05 driver that is totaling Roon and it's only fixed with a restart. All is good now and Hqplayer actually sounds pretty good. I wouldn't say it bests the M-scaler just yet though, but @GoldenOne 's suggestion of using 18 bits as a setting has helped.
Any suggestions for USB streamer/DDC or filter? I am also curios, do USB reclockers even make sense? So many people swear by the Innuos Phoenix, but I just can't find the reason why it would help.
Whether it's better to use USB or a synchronous connection (AES/SPDIF/I2S) depends on the quality of the DDC vs the quality of the USB implementation/internal clocking of your DAC.
USUALLY, if your DAC has I2S input that's the best way to go. Grab a high performance DDC like an Audio-GD DI20HE or Singxer SU6.
The DAVE does not though so something like the SRC-DX is probably the best option to make sure you can still do the full 768khz.
As to USB reclockers/filters, there are two aspects.
Firstly, 'reclocking' on USB basically just means retransmission/a repeater. This is handy if you're doing longer runs but will not result in a quality improvement/jitter reduction as USB does not provide a clock signal in the same way that I2S/AES/SPDIF do.
Reclocking SPDIF/I2S provides a demonstrable change in performance at the output of the DAC because that clock signal coming from the DDC is controlling the DAC itself. And so a lower jitter DDC will provide a lower jitter output at the DAC analog outs.
Using a high performance clock for the USB controller chip will not provide a benefit to timing at the DAC as there is no clock signal. In fact, USB audio isn't even sent in a constant stream anyway. It's sent in chunks at irregular intervals as instructed by the DAC itself, put into a buffer, and then the DAC uses its OWN clock to convert from that buffer.
As long as that buffer isn't either empty or full, it doesn't matter what the timing of extra stuff arriving into the buffer is. If you check your mailbox at mid-day every day, it doesn't matter if the postman puts letters in there at 10am or 11am.
Your DAC's jitter performance is dependent on its own clocks, NOT the clocks in the USB transmitters.
The second aspect is noise isolation or filtering.
Most of the USB 'reclockers' will have some form of filtering in them to reduce noise on the 5v/ground lines. This can help when you're connecting your DAC to a powerful PC especially, as a big PC is just about the noisiest device you can have in an audio chain. Sometimes this will have an effect that is directly audible, such as hearing GPU whine through the output of your DAC.
And sometimes it's indirectly-audible stuff. For example noise causing the clocks in your DAC to perform worse and increase jitter. Meaning you won't get directly audible noise but the quality of playback may be poorer.
If you want to completely eliminate noise, get something like an ifi iGalvanic or Intona 7055-C. These provide full galvanic isolation, meaning there is literally no way at all for noise to get from the source to the DAC. You could set off a defibrillator on one end and your DAC wouldn't see it.
