rcoleman1
Definitely...great hi-res album.Challenge your DX220 and Amp8EX combo on this track for Bass ride and fidelity joyment
If you want to solve the bug of the persistent icon in the upper left corner, you only need to change theme on Mango OS (for example choose the default orange theme) and put again the dark theme.
So apparently me and @somnarium has the same volume knob problem after using the AMP8EX
@somnarium did you have the problem straight away after using the AMP8EX?
Might be a (re set) planTry disconnecting the Ribbon cables from the volume wheel and reconnect it again. It can be done by lifting the black plastic tab and pull it out.
Yes. Take your fingernail and gently lift up that tiny black section. It will release the ribbon cable and you can easily pull it out.
Once you reinsert the cable and make sure it's seated properly press the black tab back down to lock it in place.
I'm the one Vince recalled that had a similar issue, but for me, the ribbon cable was accidentally damaged due to the repeated strain I put on it during modding. You wouldn't have had that issue.
Please don't raise your expectations though as this may not clear up your issue, but it's worth a shot since you have everything opened up.
