- Oct 14, 2013
Same here, would the Max have the same OS and steaming capabilities as DX220? If yes then I might grab one. Have they given the output power of the Max out?
I am kept in the blues as much as everyone here. Thanks to @Sonywalkmanuser for this translations from Ibasso posts.
1. The power supply of the whole machine adopts a separate power supply scheme for the analog and digital parts, and each uses an independent charge management system. Digital and analog part control and communication are completely isolated with optocoupler and 12C isolation device, completely without interference.
2. The AMP amp part uses a high-voltage battery pack of +/- 8.4V to directly supply power. There is no boost during the whole process, the power is surging, and it is pure and powerful.
3. Based on the well-received AMP8 card line, the ultra-class A discrete amp circuit is optimized, which eliminates the switching distortion of the transistor. While possessing the taste of a class-A amplifier, it can also significantly reduce heat generation. Disadvantages of this type of amplification line are that it generates a lot of heat and consumes a lot of power.
4. Equipped with 4.4mm balanced LO / PO + 3.5mm single-ended PO three interfaces, single-ended maximum output of 4.4Vrms, balanced maximum output of 8.8Vrms, 4.4mm balanced LO output of 4.4Vrms.
5, Kemet polymer package capacitors are used in large quantities, Toshin UTSJ, Panasonic, Nichicon, Amtrans and other Japanese audio capacitors.
6, custom 4-gang analog potentiometer. The difference between channels is controlled within 2dB.
