Melvins
Fake trader feedback from duplicate account: Frankzappa92.
Aka: Melvins92
BAD TRADER
- May 14, 2010
The M-stage is a very good sounding amp to my ears. Who is sobbing? lol
Crying because the O2 is not the world's greatest headphone amp!
No one claimed it was. What even makes the "greatest amp"? In my opinion there are tons of amps tied for first place, including the O2. I strive for transparency in my gear. If I can't hear the amp, I dig it. My matrix didn't noticeably color the music compared to my O2, but then again.. back then I wasn't using the super relentless t50rp. That headphone is really revealing. Maybe the differences between the o2 and matrix would have been more noticeable.
i couldn't tell a difference using Magnums or hd595. I think that speaks highly for both amps.
Maybe I should have added a "Sarcasm Alert!"
BTW, if I can't hear the amp, then I check to see if it is plugged in or the On/Off switch is set to ON!
Ra-1
Then you use your amps as an EQ... To each their own man.
buy MS Pro it is sweet headphoneand it is accordng to a few people the most close production headphone to HP2 and amp I know it is probably more than you want spend but many people like them overal with Mapple Tree as sombody already recomended.
And I disagree that Grado sounds good out of mp3 player it is harsh and tones really no good, truth is some lower models like SR225 sound very nice out of portable dac/amps but for example MS Pro did not show what they can. So get Mapple Tree or some nice Jfet solid state amp which is a little smoother like HeadAmp Lite/GS1 or diy Dispre II v4
Perhaps you could explain the disdain for using an "amp as an EQ". An equalizer is a deliberate frequency response modifier. An amp may also be a response modifier, and if the results are favorable, it's also an EQ. How is that different? In fact, an EQ, if analog, may contain a lot more active electronics than an amp, increasing the chances for distortion and noise. A digital EQ, is different of course, so long as its positioned in the bit stream before the DAC, but I'm hoping you're not referring to the EQ inside an iPod, which is frustratingly simplistic from a control standpoint, and remarkably dirty from an audio standpoint.
Just confused as to how you think one method is different enough to be so much more preferred.
Okay, when you use an amp as EQ you are forever deciding to color all of your music from here on out and to some unknown perimeters (unless your ears are that good. I could probably listen for a while and be close to knowing exactly how much the amp is coloring different frequency bands, but I've also been listening critically for two years now. I wouldn't expect a beginner to be able to do this, at all) . What works for one genre will likely not be ideal for another.. Now, if your amp somehow manages to perfectly pair with your headphone and works for all genres, great. If you long listen to one genre, great. But, someone just starting out should definitely shoot for neutral, uncolored gear while they are trying to find a pair of headphones that suits them. If your happy with tubes, I don't care.. I'm glad you are happy. I just wouldn't suggest anyone to use them. Particularly a beginner/someone on a budget.
I definitely was not suggesting an analog EQ and I never said anything about an iPod, ever. OTHER people in this thread own iPods
OK, but when you pick your headphones you've just done exactly that...settled into living with "permanent" colored sound, probably a bit worse because accurate headphones are not the norm, they're actually the exception. You've colored everything you play just by choosing that particular pair of headphones. If a headphone amp results in generally improved sound, reversing or compensating for some other deficiency, what's the problem? It's actually the first definition of equalization: compensation for undesired frequency response. Might even consider it the headphone equivalent of room EQ.
You're referring to the acquired skill of identifying response issues and responding to them. This skill is admittedly not found in beginners, though most can identify the large general issues, like they don't think there's enough bass or enough treble. And, everyone has at least some reference to go by: life itself.
I'll beg to disagree that EQ is genre specific. Good sounding gear is good sounding gear, but there are many degrees of wrong that might compliment certain types. It would be very unusual to have high quality gear that sounds wrong on some genres. While mastering labs don't have codified monitor standards, mastering engineers are pretty sensitive guys, and it turns out their monitor systems aren't radically different. If a mix sounds unusual (too dull, bright, bass-heavy, etc) it was probably deliberately mastered that way. Who are we to try to apply an inverse EQ curve to an unknown mastering EQ? I favor the "get it right, play it all the same" approach to experience what they meant for me to hear.
Anyone who deliberately buys colored gear, headphones or otherwise, will eventually tire of it, regardless of genre. I would add that everyone should shoot for neutrality, as it's very easy to move away from neutral, but much harder to get there from severely colored.
The tube thing is personal and highly psycho-suggetive. The end result of amp design has much less to do with the active component, more to do with good circuit design. The high operating impedances of tubes make driving a load directly hard to do, and frankly, mostly what you get is the result of huge engineering compromises just for the sake of using a tube. Apply the most appropriate technology, get the best result. Tubes do provide a tactile and visual influence that is inescapable. I know I'll be shot at with a tubular blunderbuss for this, but I believe it to be true, and that's having grown up in audio with tubes...the first time around, not the various resurrections. I built my own tube gear, and preferred tube amps until solid state designs caught up, which took a while.
Good to hear you wren't advocating the built-in iPod EQ! But analog EQ can be good, so can digital EQ. There's no picking a favorite technology. There are bad examples in both worlds too.
Just to wrap, I don't see anything wrong with using the pairing of an amp and headphones as an audible improvement equalizer that you live with long term. You already are doing it to a much greater extent with the headphones themselves.
I appreciate your argument.. We will just have to agree to disagree on a couple of the points.
Mainly that it's a good idea to add more coloration via a tube amp when you already probably have colored headphones. I'd suggest to shoot for neutral or transparent gear.. and then to try to use EQ to work out the quirks in the given headphone.
Also, if you have "transparent" gear, you can better pick your headphones. You'll at least have a better idea what the headphones sound like instead of what the headphones and a tube amp sound like.
I don't really think EQ is genre specific.. so much as it is mastering specific. Lots and lots of music is mastered and recorded just terribly. EQ can really help with that (and so can lower tier headphones, actually. They hide some of the glaring errors). I mean, even really big names release terribly mastered albums. A rather large section of my music collection has probably never even seen a real studio or mastering engineer.. Some of these recordings still manage to sound better than some of the "professionally mastered" albums in my library. It's really a bummer to discover clipping present on a master done by a "pro".
There is no right or wrong method. Whatever makes the user enjoy the music is what's right for them. I don't think it's inherently wrong to use tube gear.. I just don't suggest it to beginners.
*throws his arms up into the air* I'd probably have some sort of a tube amp if I had the money.. Just for the sake of having one. They do have gobs of style, if nothing else.
FTR, I've heard incredibly neutral tube amps and some very coloured SS devices. This generalization is often made, but rarely accurate IME.
