Uncle Erik
Uncle Exotic
- Mar 18, 2006
If you want to see tube linearity, pull up the www.nj7p.org datasheets for whatever tube you're interested in. You can see the curves; they're all different. A copy of the RCA Receiving Tube manual also has them. Linearity depends on how you bias them.
I've also picked up a lot from the books by Bruce Rozenblit and Morgan Jones, the old Navy NEETS manuals, and various texts available at www.pmillett.com.
Distortion is not the be-all-end-all of amplification. Humans can't hear it that well and read up on even versus off order harmonics. Tubes distort in a much more musical way than solid state does. These figures get beaten to death in debates, but the truth is people enjoy the sound. DHTs aren't terribly accurate, but everyone seems to like what they do to the mids. Vocals can sound more real than real life. Accurate, no. Enjoyable, yes! No reproduction will be as good as a live event. I see reproduction as a separate experience. If a 2A3 pleases me, then I'll use it.
One of the wonderful things about tubes is that there are hundreds of thousands of variations. You can get exactly what you want.
As for an accurate amp, I really love the Zana Deux. First, and foremost, it gets the power supply right. Four chokes, external transformer, and exceptional filtering. The 6C33C tubes are run with a nicely low output impedance, something like 5-6 Ohms in an OTL configuration. The signal is taken off the plate, which is a nice variation from the usual and sounds more musical. A little feedback is added, but not much. Its output is linear out to 60kHz. All a result of careful engineering and tube selection. Moreover, it's entirely point-to-point, so I'll be able to keep it running for a lifetime.
And I do agree that solid state can be excellent. I have a Dynalo, M^3 and CK2III around. Upcoming projects include a 3 channel Beta22, DynaMid and DynaMight. Also a few more tube amps of varying topologies and tubes. I want to experience it all. But for long-term use, I'm with tubes. Any of the solid state amps will be doorstops if I can't get replacement chips for them.
As for the Dynalo, there is a company making new ones for $300 right now. The boards and chips are available through AMB if you want to roll your own - I built one for $120 a few years back. Also, there was a Gilmore Lite (same thing) in the For Sale Forum earlier today.
