HWB3
Try audiophileninja.com. I got my cable from there and it was less than $60. Very pleased with it.
Thank you. The thing is being outside USA makes it more difficult. Amazon its a safer choice.Try audiophileninja.com. I got my cable from there and it was less than $60. Very pleased with it.
If you want also changes in the sound, get some OCC (more bass) or SP-OCC (more treble) cable. For example - https://www.aliexpress.com/item/1005003285306782.htmlHi guys. Is there are any budget cable (around 60 bucks tops) that makes an actual upgrade from the stock cable, in both construction and signal quality (sound?)?
thank you! the link does not work, but if you could just tell the name of the cable (OCC) and I will find it on AliExpressIf you want also changes in the sound, get some OCC (more bass) or PC-OCC (more treble) cable. For example - https://www.aliexpress.com/item/1005003285306782.html
Sorry to you, I wanted to write SP-OCC (silver plated) not PC.thank you! the link does not work, but if you could just tell the name of the cable (OCC) and I will find it on AliExpress
Edit: Oh sorry, it worked. Got it! thank you so much
Xduoo xd05 plus ?Any recommendation for an amp / dac powerful enough to drive well the k702? Without breaking the bank and if possible one boosting the bass a bit too...
I personally think the stock cable sounds fine, it just feels horrid and cheap. But then in my opinions, the K702s are not build well either.Hi guys. Is there are any budget cable (around 60 bucks tops) that makes an actual upgrade from the stock cable, in both construction and signal quality (sound?)?
There are some cheap options. The FiiO A3 drove my K702s very well. It has the power to get these louder than you ever would want and it also has a bass boost switch that boosts the low end at around the 75hz region by about 4db. It is nice and clean too as it doesn't mess up the mid bass. I would say it suited the K702s quite well when you wanted the extra punch.Any recommendation for an amp / dac powerful enough to drive well the k702? Without breaking the bank and if possible one boosting the bass a bit too...
(When both EQd to Harman curve)Getting a bit of an upgrade itch here. Are the Sundaras considered an upgrade over the AKG K702 overall (minus soundstage of course)?
Thank you. That's what I suspected. I was thinking maybe upgrading to a Hifiman Edition XS in the future, what do you think about that one?(When both EQd to Harman curve)
Sundara
+ : a bit faster; timbre is nicer; upper mids are cleaner and less shouty; more agile, deeper and impactful bass; treble sounds natural; easier to drive
- : slightly less detailed in the lower mids; comfortable but quite a bit heavier; gets more congested at times
I've kept A/Bing these two headphones for a time in various music genres and I've concluded the Sundara is not a worthy upgrade. There's a 5-10% improvement generally, mostly with electronic music and pop. I'd say save money for something like the Audeze LCD-2C, HiFiMAN Ananda or the Focal Elex/Elear.
I've previously owned other Hifiman headphones with the same solid material type of headband as the Edition XS (HE400i 2020 and HE400se) and they were supremely uncomfortable. I don't know about the XS, but I'd take the Ananda if you want a comfortable pair of headphones with nice grip over your head and good weight distribution. They're a good upgrade over the K702, although I think soundwise it's the weakest of the headphones I've recommended. The Audeze has killer dynamics and bass and mids (but needs some EQing), same with the Focal, they're amazing, but they have a bit of a weird treble frequency response.Thank you. That's what I suspected. I was thinking maybe upgrading to a Hifiman Edition XS in the future, what do you think about that one?
