pack21
- Dec 25, 2011
wrong topic. sorry.
You should look at the alo dac/amp combo and keep the akg's you won't find better at the moment so don't even try!That's the algoRythm solo dac and rxmk3-b headphone amp www.aloaudio.com/cypher-labs-algorhythm-solo-black-pre-order www.aloaudio.com/ p.s the iphone doesn't do them justice, get the better dac/amp combo and use your phone to make calls and let the dac of the solo and amp show you what the akg's can really do!
So far, I have in searching for an upgrade, auditioned the FI-BA-SS, FitEar ToGo 111 and the Final Audio Design Piano Forte X-G.
Interestingly the AKGs sound the best to my ears, even though the Piano Forte X-G was definitely more pricy.
Any help would be appreciated. I use my earphones with either a macbook air of a iPhone 4S, playing songs bought from the iTune Store. Thanks again and please be gentle with this newbie.
Well, just finished repacking the 3003s and will send back today. FOR ME; doing a quick comparison between the Shure 535s Bronze and these over three songs, simulating the setting I will use them in the most (airplane with hum of engines and other background sounds), I liked the Shure's better. IMHO and untrained ear, I liked the sound of the Shure's over the 3003s as well as the isolation. It is just as some of you said, if we use the Shure's as 100% isolation....the AKG's are about 80-85%.
I have taken the advise from several Head-FIers and have Westone 4Rs on the way from Earphone Solutions. They arrive tomorrow. I am excited to try these and hope they are a step up in SQ from the 535s. I have not doubt the isolation will be at lest equal.
I really wanted to love the 3003s. Yesterday, in attempt to that end, I sent PMs to a bunch of you. Mahalo Nui Loa (thank you very much) to all for taking the time to answer me both PM and in the threads.
If you actually tried the Piano Forte X-G, I want some pics! Doubtful since it has pretty much never been seen in the wild. You probably tried the X-CC. Piano Fortes are a completely different kind of headphone and so shouldn't be regarded as an upgrade in the traditional sense. They either move you or they don't.
Poor man's K3003.
I don't have pictures but I can try to describe it for you, it is gold in colour, looks really strange, like a hershey kiss glued onto a pair of earphones except that the point which goes into the ears.... are the same colour and material as the body of the earphone, completely made of metal and painted in the same gold colour. It has no soft silicon or form material at the insertion point just that metal tip. I found it quite uncomfortable actually(imagine sticking metal straight into your ears). The left side kept popping out so I had to squeeze them into my ears, which was definitely not a pleasant feeling. With the AKG K3003 I use the smallest tips, it is a good fit for me, most likely my ears are too small for the piano forte. You could be right since I don't really know much about earphones and such, I basically asked if i could audition the best earphones from final audio design and the sales person brought out the piano forte that I tried. I had to put on a pair of gloves to handle them, which of course made it very difficult to actually handle the earphones and the iPhone at the same time since I could not interact with the iPhone screen with gloves on. The earphones stick out, like two elongated golden knobs coming out of the ears. I had to keep pushing the left one in my ears as it felt like it was going to pop out. The sound was not as nice as the AKG K3003 to me. I can't really put it in words since I don't know the right terms to use, but it sounded like the female vocalist was further away on the piano forte compared to the AKG K3003. Also on the AKG K3003 there is a kind of wetness to the singer's voice, it feels like there is a texture to the air that pours out of her throat as she sings, almost like a slight rumble of throatiness. It's beautifully rendered on the AKGs but not present on the piano forte that I tried. I also much prefer the way base is represented on the AKGs. The piano forte were quite expensive, if I am not mistaken it cost almost $3000. Audition them at an audio show in Singapore(Raffles city), last Sat, the company that carried said product was Jaben. Sales person was really friendly and helpful. Hopefully all these information would help you have a clearer picture of the earphone I tried, sorry i can't make it any clearer as I had said in my earlier post, I am a total newbie.
Thanks. No argument that you heard the expensive Piano Forte X; the only question is whether it was truly gold in color (gold plated, the X-G) or ion-coated chrome copper (the X-CC). Maybe it really was the fabled X-G. Here is an archive page that shows mock-ups of each. This (near the bottom of the page) is what the X-CC (now known commercially as the X) looks like in real life. I cannot show you a picture of what the X-G looks like in real life; there are no pictures out there. It was either discontinued quickly or never released. That is why I am intrigued that you might have seen one. The two would sound exactly the same; it is just a coating difference.
Edit: MuppetFace somehow found this one photograph of the whole line-up including the X-G (bottom) and the X-CC (top). I cannot find a single other picture of the X-G in the wild.
Are those a newer model they are releasing? Looks interesting ....
Poor man's K3003.
