musicinmymind
- Jan 31, 2012
The K3003 is not hard to drive at all. My DX90 does fine with it, then again so does my phone. You'll be fine.
Great, Thx
Lucky me just got K3003i new from harman site for 490$. They was having one day sales for employees and my friend got one for me.
One it arrives, will be able to compare with IE-800
bargain , you're in for a treat
you will also be selling your re-600 , i know i did days after getting the K3003 (and i really liked my re600)
congrats & enjoy , let us know how it stands with your ie800
My beloved K3003i has a short in the right ear piece. I purchased them in dec from world wide stereo. Does anyone know what I have to do to get replacement and how long of time frame will it be?
Yeah that's the external paper box. The serial badge on the K3K is affixed to a piece of stainless steel which is glued to a foam block that is inserted into the K3K's display box. It can jostle loose or be displaced unfortunately. Depending on how old that unit is, it could be in the high thousands or low. I had two units, one was before 2,000, and the other was about 30,000 or so.
Hi guys! Can anyone check your box? I'm interested in buying second-hand K3003, but I need to know the serial number of them. The seller sent me this picture:
Where is the serial number here? Is it 1241 or 3219?
For some reason his box doesn't have the metal plate with serial number - should I worry about that?
What I'm saying is the metal plate probably came loose at one point and isn't anything to worry about. There aren't any fake K3003's as far as I know
if i remember correctly (as i do not open it very often) there is the S/N inside the box
what did the seller tell you ? if he is from here and he has a trustworthy profile , all is well i guess
edit : i see you say the seller does not have the box
when did he purchase them ?
