which of the 2 available tips are the ones to get ? the site shows 2 different kinds
https://www.finalaudio.nl/nl/webshop.html
Ear pads
Forget the B TYPE!!(********!) TAKE THE A'S
Regards NOMAX
Ear pads
I got my Final Audio ear tips today.
My first impressions:
The tips are very tight so it is not easy to set them to the K3003, but at least it works.
The sound impression changes to a darker sound, a little bit like my LCD-2. The insulation is better as the original tips and the rest you hear from outside is also darker. I'm loving the changes the tips make.
well it looks like final audio has an official dealer in Greece , so i will go by their place and see if they have any stock tips for sale
the K3 stock tips sound good but i am intrigued by nomax's praise of the FA tips.
So Angie vs K3003 has been cancelled as I got the Layla instead
She's been making love to my ears for the last couple of nights
Ok, I finally found the time to try FAD tips on my K3003 and compare them to the stock tips. Please note that I personally get a really good fit and seal with stock tips and my results may not apply to you, especially if you're having a problem in that regard. The FAD tips are a lot more rubbery and sticky, so I'd recommend them to those who feel that their seal with stock tips is not secure or possibly even leaky.
The FAD tips I used for the comparison look like Type A, but are from the new Heaven VII, so the may not be exactly the same as the older ones.
That said, here are my stock and FAD tips side by side:
The FAD tips' opening is slightly narrower than that of the nozzle (and stock tips), which seems to cause in a mild reverse-horn effect and attenuate treble response. At least that's how I hear it, because treble sounds slightly more subdued and the midrange more forward in comparison.
Interestingly, bass response is depends on how far the tips are pushed onto the nozzle, as the placement on the left sounds less bassy to my ears than the one on right:
(Note that in either case, the nozzle vent is not covered by the tip stem)
I can see how the change in sound signature may be welcome by those who feel that the K3003 sound a bit too treble happy and forward with stock tips, but apart from a more downsloping treble response (and as a consequence, slightly warmer and fuller mids). I haven't been able to detect any noteworthy improvements in sound quality.
Last not least, note that you don't need to buy FAD tips to tame treble response, since a simple piece of dried alcohol swab tucked between nozzle and tip will also do the trick:
Disclaimer: just my 2c, ymmv, etc...
