up late
- Feb 19, 2013
congrats - hope you enjoy it as much as i do
hoping my gut feeling is right , i went ahead and bought a used like-new pair of K3003
the price was just too good to pass , i guess i deserved a late xmas present in a very turbulent year (YOLO)
this place is a wallet killer
thanx to M13 for his input/thoughts , will let you know how these sound , hopefully they are quite an upgrade from my RE-272/600
If you're looking to go the custom route, I'd recommend the UERM. If you're looking for tips... I'd probably try looking into Comply tips. I wouldn't worry about break in, just listen to them.
Ultimate Ears' Reference Monitor. Commonly abbreviated as UERM. They are simply stellar phones with fantastic transparency and balance
Using Comply tips with the high boost filter could sound somewhere between the reference and the high boost, I think.
Hello everyone. I just bought a K3003i and yesterday was my first day trying and I like to share few things to see if you can help me.
I think the IEM is beautiful, very well designed, but unfortunately the fit for my ears is terrible. I can't get a seal with any of the tips provided because I have an small ear canal. I have tried some triple flange tips from other manufacturers that fit the K3003i, but as I don't have small size still hurts a lot. After a couple of hours I had a tremendous headache.
Any advise on tips that fit the K3003 and small ear canals while maintaining good SQ?
On top, one thing I noticed of the k3003i, is that to really get the dynamics of the sound and the punchy bass, you need to flow some juice. At low volume is not that engaging, this results again in a very tiring experience. I have tried the reference filter and it is good albeit I find that some vocals a bit strange, like there is a mismatch between the frequencies, maybe end a bit V-shaped sound. On the contrary the treble filter create an extremely good sound, with fantastic vocals and resolution, really outstanding clarity. Unfortunately the treble filter loses a bit of the bass presence resulting in a sound that is good for acoustic, classical etc but not as great for other types of music. It is a pity there is no filter between the reference and the treble boost, that would be perfect.
I am startngt yo think that for my ears the only way to have comfort is to go custom. If any of you can recommend a custom IEM that sounds similar to the K3003 (resolving, clear, good dynamics, good soundstage, with excellent treble but not too aggressive) please advise as I may just need to take that route. I think universals are just hard for small ear canals.
Please advise on tips for small ear canals and also please advise on how long I need to :"break-in" the K3003i to get to its "real" sound.
Thanks indeed.
It seems the manufacturer was well aware of K3003's bulkiness, and it is virtually impossible for the users to insert this giant into their ear canals. So AKG designed the product in such way that the frequency response measured at a shallow insertion depth to be the reference.
Source: Rin's K3003 analysis.
Bottom line: don't try to shove them deep into your ears, the K3003 have been designed for a shallow seal. Also, their isolation isn't the best, so you may not immediately notice when you've got a seal.
Imo these are some of the most engaging low volume IEMs on the market, but of course you'll need a good and painless fit to enjoy them.
which other tips suit K3003 ? i find the comply tips not to my liking with my previous iems as they tend to muffle the highs .
