I'm not sure I completely follow what you're saying, as to the benefit of the XLR. What you're saying is that the 4 pin XLR would enable me to run it off speaker outputs (how is that done?). By 4 pin Xlr to Balanced 1/4" TRS jack do you mean an adaptor that would make it possible to use the XLR with regular headphone outputs?
If that is so I'm not sure the XLR is for me. I do have an amp at home (a nad 3020) but It really wouldn't fit in my room here in the dorms. (Two architects living in one really small room
) A headphone amp with a small footprint is the best I could do. Or would I benefit from the XLR with a headphone amp as well?
Currently at home I run it form my Kenwood Basic C2 preamp, and it doesn't seem to have enough power to drive it properly, I think. It goes loud enough, but the bass isn't very controlled or precise, and the sound seems to fall apart at higher volumes. I don't mean LOUD, just louder than normal. Don't get me wrong, I'm no bass head, but i really think this headphone could do better. On low volume it sounds quite nice.
