I might be willing to try out the ES100 since it is pretty cheap. The other DAP's etc. are not only too much extra to carry, but add a big amount on the price. At that point I'd just go for the denon 9200's since they sound great.
I only rarely need it on the go, so when I test out the Aeon2's with the other headphones, it is maybe possible to choose that now I am definitely looking for something with a good soundstage, so hoping it works out. I am guessing it should work just fine with the Element II dac/amp power wise.
Yes, I can see where you're coming from.
I do also think that a Bluetooth receiver would be the best solution in your case. It's very easy to get spoiled with the convenience those kind of devices offer once one get used to it
Trying them out with my Qudelix 5K right now because my wife is using my laptop at my desk (where my desktop setup also is) for a Zoom call so I dont have access to my usual desktop or laptop sources. Perfect excuse to test my Aeon 2 Closed Noire with my 5K and, although I definitely prefer them with my Grace Design m900 (usually use my Noire with this at my standing desk/laptop setup in my living room) the Noire isn't too bad with the 5K (esp for a tiny $110 device). Here is a screenshot to show where my volume is currently (streaming Amazon Music HD via LDAC 990 from my LG V60 --> Qudelix 5K --> Hart Audio cable with 2.5mm balanced interconnect --> Aeon 2 Closed Noire). Plenty of headroom for me but I think I do tend to listen at lower volumes than others.
