A Review of MandarinEs Foam Tips
post-13797914
Post #121 of 397
tuckers
I got both the regular and the wide versions. Using them on my DITA The Answers, I find I prefer the recommended wide ones in medium. In Complys I always use the large, but these are harder and don't compress down like the Compys so I find the mediums are a better fit. Good bass, possibly better than the Complys, and a bit brighter sound overall. I like it. So far, I find that they shift more in the ears so the sound quality shifts as well, so for active sessions at the gym they tend to go in and out for ideal sound. Not sure if that will reduce as my ears get used to them. But I am happy with them.
The regular size ones pump up the mid bass a lot compared to the recommended wide ones, and it's too much, it also does something odd to the soundstaging.
Also, they are the best sound isolating tips I have ever used, they block noise very well.
post-13864506
Post #122 of 397
garcsa
Member of the Trade: Mandarines IEM Memory Foam Eartips
f r i d a y
Boss - Hommage à Easybeats :
"Friday On My Mind" ....
Reactions: HungryPanda
post-13865376
Post #123 of 397
Tim Le
Can someone give a brief comparison between the Symbios (wide bore), Spiral Fit, and Spin Fits? Much appreciated :)
post-13865787
Post #124 of 397
karloil
Singapore
Singapore
hhmmmm, always get 1 size smaller (than your usual) for MandarinEs as the memory foam is a bit chunky and you can't really insert them into the ear canal. Comfort wise, if you get the proper size for the MandarinEs - they are a lot better in long use. Better isolation (with the help of the foams).
SQ wise - really haven't paid much attention to it as my priority is Comfort 1st, then Isolation. So really can't comment.
Reactions: Tim Le
post-13865861
Post #125 of 397
garcsa
post-13956040
Post #126 of 397
Techguy17
New York
New York
I just received my Symbio W order for my Sony WF-1000x and quite impressed with sound quality and clarity. Unfortunately, the noise isolation on the subway is disappointing in comparison to other memory foam tips. Not sure if anyone else noticed this since earlier reviews stated good isolation. I’ll try on a flight this weekend and compare.
post-13958468
Post #127 of 397
joncirca57
Any guess which diameter might fit B&O E8s? thanks!
post-13963436
Post #128 of 397
Moebiushaydn
I felt the same until I dropped the tips a size down, which resulted in a better seal, and thus better isolation.
post-13963705
Post #129 of 397
XybernetIQ
I also received the Symbio W ordered for my Zeus XRA. In addition to @garcsa prompt service, the tips are well suited to my habit of wearing IEM's. The fit is good, they are comfortable to wear for a long time without fatigue and the isolation is good. I bought both L and M sizes, but I discovered that M has a better fit than L. I usually wear L from Comply Foam for instance. They are my favourite tips for the moment. HTH
post-13965678
Post #130 of 397
Jearly410
San Antonio TX
San Antonio TX
The wide bore really makes the campfire andromeda a special iem. When I listened the first time with the tips I was in awe.
Reactions: Aslshark
post-13972324
Post #131 of 397
Techguy17
New York
New York
Thanks for the suggestion. I guesss I’ll have to wait for extra small size to be manufactured and then.
post-13981097
Post #132 of 397
ivo001
Netherlands
Netherlands
@garcsa I see on the listing that they ship in a set of 3.
Is it also possible to order a mix of Symbio N and Symbo W?
Like:
- Medium N
- Medium W
- Small N
post-13982794
Post #134 of 397
aaf evo
Houston, TX
Houston, TX
Ordered mine on be 12th for my Fourté. Can’t wait to receive them!
post-13995392
Post #135 of 397
foshow
Hey guys, any idea if the "Symbio N" is compatible with the Shure SE846? Thanks in advance for the replies.
