A Review of MandarinEs Foam Tips
Jul 8, 2017 at 7:18 AM Post #61 of 451
Jul 16, 2017 at 12:26 AM Post #66 of 451
Symbio with the YK-1S
Jul 16, 2017 at 4:27 AM Post #67 of 451
I would love to try a wider bore model to use with my iSINE. Size would be Comply 600 equivalent.
Jul 16, 2017 at 4:43 AM Post #69 of 451
So there is a MandarinEs size equivalent to Comply 600?
Jul 16, 2017 at 2:03 PM Post #71 of 451
If used for longer time the Symbios are becoming uncomfortable. If there is a plan for a revised version I suggest to use softer foam and to avoid that seam.
Thanks for suggestion. We have some concrete plans for new product....
Jul 26, 2017 at 1:03 AM Post #72 of 451
DAMN!! I thought I had really good seal with the millions of different types of tips I already have, but this takes the cake! I am simply blown away with the seal, and therefore the bass from my iems. Good work guys.
Regards,
Jul 26, 2017 at 1:50 AM Post #73 of 451
Anyone tried these on Noble wide bores? Would love to measure and test these vs. SpinFit/Comply/Silicon!
