jgazal
- Nov 28, 2006
yet very few people feel like this sounds flat when a headphone is calibrated that way. we have the expected variations from HRTF, an extra variable compared to the average human target, but one we expect and can deal with. but then comes something like the almost universal desire to get more low end that probably comes from a desire to compensate for the lack of tactile bass on headphones. how do we quantify that objectively? how a use tries to turn body vibration into increased low frequency at the eardrum? despite a purely objective approach, the result doesn't work as is because we did not and could not account for all the variables in the system. so what we have is a simplified system and only subjectivity can turn that into something feeling neutral, or not.
I get the idea of the Realiser A8/A16 where you take one specific room and try to mimic the sound for one specific user with one specific headphone. the target is clear, the reference is clear. it's all user specific. that to me makes sense, it's not a matter of spatial distortion, it's an attempt to simulate the experience of one room for one dude. we lack tactile subs and maybe looking at the speakers, but otherwise it's pretty complete. (...)
about analogsurviver's comment on subs, Floyd Toole mentioned a few times that we might not even need actual subs to replace the lack of tactile bass. vibrations from any source can subjectively do wonders even if they're not at the proper frequency or rhythm. to dumb it down, if we shake a little, it seems to feel more realistic than if we have only headphones.
I never got to try the stuff that makes your chair vibrate with the music, was that a total bust or are there people actually enjoying that stuff?
Sorry to cut your great post, but since you are at it, I would like to expand the topic of tactile/haptic/kinetic transducers.
I guess those kind of transducers that propagate low frequencies through solids (your couch, chair or your own body) instead of air have the advantage of avoiding room nodes and bass overhigh and they go deeper in frequencies if compared with subwoofers at the same price.
B. The crosstalk avoidance binauralization route
B.1 The crosstalk avoidance binauralization with headphones
And what you can do with DSPs like the Smyth Research Realiser A16?
Add tactile/haptic transducers and you feel bone conducting bass not affected by the acoustics of your listening room.
So I was searching for the most linear solution and I have found Crowson Technology tactile transducers, Subpac S2 seated haptic transducers, Subpac MX2 and Woojer Ryg (eta early 2018) wearable haptic transducers:
Crowson and Subpac have more reviews.
See, for instance, Subpac reviews:
so, just got it up and running. The most fascinating thing to me is that it makes me seemingly "hear" the bass with my ears more. Like I know it's an audio illusion, but the bass guitar on Fiona Apple's Criminal sounds louder with subpac on. Because they're running completely independently through entirely different DACs, I can control the subpac's and my HD800's volume completely independently. And when I turn down the subpac without even touching the HD800's volume, it SOUNDS like the bass is going down as well. Like it seems like just in my ears it's less loud without the subpac on. At first I though that maybe I was hearing some bleed through the open HD800s, but the effect still happens with sealed IEMs. And I don't hear anything coming from the subpac if I have the HD800s turned all the way down. But when they're working together, the subpac seems to make bass sound louder, seemingly, to my ears. So funny.
I have also noticed with the M2, wanting to wear it on the front, getting a good tight fit seems key. Just casually having it lay there doesn't have the same effect, it's almost like the bass gets loose and unrefined.
I've noticed that as well. It has everything to do with that being the way we actually hear bass in the real world. We not only hear deep bass, we feel it with our bodies. That's the gestalt ofdeep bass. When the tactile element is missing, our perceptual apparatus tells us something is missing and we don't "hear" the bass.
With the subpac, the trick is to find the right level match so the tactile part is not calling too much attention to itself. When you achieve the sweet spot, it just sounds like really deep bass.
Adds about half an octave of deep bass to the HD 800's, now doesn't it?
Comments on M2 inverted vs. M2 and/or S2?
I just heard about the device, and initially thought all applications would chest-mounted, e.g. using M2 inverted, as it "feels" most instinctive to me. Something feeling rumbling behind you seems a bit off![]()
it's not as big of a deal as you would think, as long as you use the unit subtly (where it is at its best). Your core isn't super sensitive directionally, it mostly just feels an omnidirectional thump. That being said, I do prefer the inverted M2. Especially if I am playing around with it at higher than natural settings.
A lot of people who use this thing go crazy with it, and have impact it produces set at ***several*** times what the natural impact would be. If you use the subpac at a "natural" level, then you almost won't think it is on, as your brain just blends it in with your heard sound, into one coherent whole. If you have it higher, the "spell is broken" and you feel the subpac as its own separate thing, in which case having it on the back is a little off-putting.
All that to say, yes, I prefer in the front, but it actually doesn't matter as much as you would think if you are using it for high fidelity musical enjoyment.
Best tip ever. Makes a huge difference.
Got my M2 this christmas. Love it.
Will also get a Smyth Realizer A16. Backed it a Kickstartert.
Compared to my Lofelt Basslet the SupPac is a bit slower. (https://lofelt.com/) But the Basslet is very small.
What do you think?
