gibosi
- Oct 18, 2012
If i use tube adapter to use 6SN7 tubes instead of 6922's. What kind of change in sound can i except ? I have Copland CTA301 mkII (6922) pre amp.
https://www.tubedepot.com/products/6sn7-to-6922-adapter
btw, can i use tubes like above CV 181-T MKII with this same adapter ?
Thanks&cheers
I know nothing about your amp... But the 6SN7 heaters draw 0.6A whereas the 6922 heaters draw only 0.3A, twice as much, so be sure your amp can handle this. Otherwise, you could damage your amp.
And yes, if you can safely roll 6SN7, you can also roll the Psvanes CV 181, which is just a "pretty" 6SN7.
